Geoffrey F4FXL Posted December 26, 2025 Posted December 26, 2025 (edited) Hi All, I have a couple of H3 based boards (Orange Pi Zero and FriendlyArm NanoPi Duo 2). With all of them I have the same issue: command like "reboot" turn the board off instead of rebooting. The workaround is to add following line in /boot/armbianEnv.txt extraargs=reboot=warm Running latest image on all of the boards. Edited December 26, 2025 by Geoffrey F4FXL corrected /etc/armbianEnv.txt => /boot/armbianEnv.txt 0 Quote
eselarm Posted December 26, 2025 Posted December 26, 2025 I think it must be /boot/armbianEnv.txt Besides that, I never had this issue with my 5 NanoPi-NEO boards, originally Armbian Buster, always in-place upgraded. Also 1 now tested with kernel 6.18, now issues. So I think you maybe need to look at what U-Boot you use, what kernel is it and logs ( all via armbianmonitor -u ) 0 Quote
Geoffrey F4FXL Posted December 26, 2025 Author Posted December 26, 2025 Ooops, you are right I meant /boot/armbianEnv.txt, I edited the topic to correct. The output of armbianmonitor -u can be found here: https://paste.armbian.com/foyunagisu What should I look for? 0 Quote
eselarm Posted December 26, 2025 Posted December 26, 2025 I do not see something clearly wrong, but likely is is a newer U-Boot, maybe something wrong there; version in SD-card you can show with: dd if=/dev/mmcblk0 count=32k status=none | strings | grep "U-Boot SPL" 0 Quote
Geoffrey F4FXL Posted December 26, 2025 Author Posted December 26, 2025 Here is the output: U-Boot SPL 2024.01_armbian-2024.01-S866c-P6b16-Ha5c2-V7d7d-Bbf55-R448a (Dec 22 2025 - 03:39:51 +0000) Note that prior to this I tried to update uboot through armbian-install, it did not change anything to my reboot issue. 0 Quote
eselarm Posted December 26, 2025 Posted December 26, 2025 OK, I have the following in my test NanoPi-NEO (using 6.18 kernel): U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-V2b78-Bb703-R448a (Mar 09 2025 - 03:54:42 +0000) Same base, but it is older and anyway different hardware, although H3 SoC. I have no more ideas why you need that extra kernel cmdline statement. I think I have seen it as well for another board/SoC, but does not ring a bell. 0 Quote
Geoffrey F4FXL Posted December 26, 2025 Author Posted December 26, 2025 The thing is that I need it on different boards .... Tried Armbian Trixie and Ubuntu based, same issue thus it might be uoot and/or kernel related. Thanks for your help though. 0 Quote
Geoffrey F4FXL Posted December 26, 2025 Author Posted December 26, 2025 (edited) Update, this is also working .... extraargs=reboot=watchdog UPDATE: It stopped working after 3 successful reboots... Edited December 26, 2025 by Geoffrey F4FXL 0 Quote
Geoffrey F4FXL Posted January 14 Author Posted January 14 Today I needed to reboot one of the Orange Pi which is at a remote location.... It did not come back to life.... Maybe some update removed the extraargs=reboot=warm parameter .... 0 Quote
Issou Posted February 17 Posted February 17 Hello, @Geoffrey F4FXLyou just saved me a lot of debugging time. I have multiple orange pi zero with h2+ and h3 and I had the same problem as you. With the reboot command, the sbc shutsdown but doesn't boot again, i need to reset the power for getting it booting again. On my side , this command extraargs=reboot=warm didn't worked but extraargs=reboot=watchdog worked perfectly. I just rebooted it 5 times in a row and it always rebooted well. My version : v25.11.2 for Orange Pi Zero running Armbian Linux 6.12.58-current-sunxi 1 Quote
Geoffrey F4FXL Posted March 2 Author Posted March 2 @Issou thanks for the feedback, I eventually got my hands on the Orange Pi zro I had in a remote location, I will make a fresh install and see how it behaves. 0 Quote
