Geoffrey F4FXL Posted 3 hours ago Posted 3 hours ago (edited) Hi All, I have a couple of H3 based boards (Orange Pi Zero and FriendlyArm NanoPi Duo 2). With all of them I have the same issue: command like "reboot" turn the board off instead of rebooting. The workaround is to add following line in /boot/armbianEnv.txt extraargs=reboot=warm Running latest image on all of the boards. Edited 1 hour ago by Geoffrey F4FXL corrected /etc/armbianEnv.txt => /boot/armbianEnv.txt 0 Quote
eselarm Posted 2 hours ago Posted 2 hours ago I think it must be /boot/armbianEnv.txt Besides that, I never had this issue with my 5 NanoPi-NEO boards, originally Armbian Buster, always in-place upgraded. Also 1 now tested with kernel 6.18, now issues. So I think you maybe need to look at what U-Boot you use, what kernel is it and logs ( all via armbianmonitor -u ) 0 Quote
Geoffrey F4FXL Posted 1 hour ago Author Posted 1 hour ago Ooops, you are right I meant /boot/armbianEnv.txt, I edited the topic to correct. The output of armbianmonitor -u can be found here: https://paste.armbian.com/foyunagisu What should I look for? 0 Quote
eselarm Posted 47 minutes ago Posted 47 minutes ago I do not see something clearly wrong, but likely is is a newer U-Boot, maybe something wrong there; version in SD-card you can show with: dd if=/dev/mmcblk0 count=32k status=none | strings | grep "U-Boot SPL" 0 Quote
Geoffrey F4FXL Posted 21 minutes ago Author Posted 21 minutes ago Here is the output: U-Boot SPL 2024.01_armbian-2024.01-S866c-P6b16-Ha5c2-V7d7d-Bbf55-R448a (Dec 22 2025 - 03:39:51 +0000) Note that prior to this I tried to update uboot through armbian-install, it did not change anything to my reboot issue. 0 Quote
