Disagrees about version of symbol module_layout after nand_sata_install
I need wifi working on an A20 board. Managed to compile the driver and change coherent_pool value to 2M and made everything work when booting from the SD card.
After that I made a nand install using the nand_sata_install.sh script with minor modifications (partition+sizes).
The system boots and everything is working right except the modprobe -v st7601Usta fails with exec format error.
Dmesg says: st7601Usta: disagrees about version of symbol module_layout
Recompiling the driver and reinstalling it does nothing.
As I understand the nand_sata_install script uses the same linux image only converted from zImage to uImage. Shouldn't the module work just out of the box after SD to NAND transition or am I missing something.
Best regards,
Mihai
