I’m really happy to share that I finally managed to port the SV6256P (SSV6X5X) SDIO Wi-Fi driver from the legacy Linux 4.4 kernel to modern kernels.
This repository contains my working port for Linux kernel 6.12 and newer, with updated mac80211/cfg80211 integration so the driver can build and run on recent Armbian systems.
The chipset is commonly used in many low-cost TV boxes and embedded devices, but the original driver only supported legacy kernels (4.4).
Now it’s functional again on modern systems, at least on my tested hardware (Allwinner H616 / X96 Q via SDIO).
Repository link:
https://github.com/cdhigh/armbian_sv6256p
I’m quite excited to finally see this old Wi-Fi chip working on a 6.x kernel 🙂
[    4.774151] ssv6x5x: importing configuration from /lib/firmware/ssv6x5x-wifi.cfg
[    4.778281] tu_ssv6xxx_sdio_init, probe @(____ptrval____)
[    4.779483] TU_SSV6XXX_SDIO mmc3:0001:1: Probing SDIO bus
[    4.779513] ssv6xxx_set_sdio_clk: set sdio clk 25000000Hz
[    4.799668] TU_SSV6XXX_SDIO mmc3:0001:1: vendor = 0x3030 device = 0x3030
[    4.825421] TU_SSV6XXX_SDIO mmc3:0001:1: dataIOPort 0x10000 regIOPort 0x10020
[    4.849181] TU_SSV6XXX_SDIO mmc3:0001:1: dataIOPort 0x10000 regIOPort 0x10020
[    4.849530] TU_SSV6XXX_SDIO mmc3:0001:1: CHIP ID: SSV6006C0
[    4.850373] ssv6x5x ops chk: tx=1 start=1 stop=1 config=1 add_if=1 rm_if=1 conf_filter=1 wake_txq=1
[    4.850402] ssv6x5x chanctx chk: any=1 all=0 emulate=1 add=1 rm=1 chg=1 assign=0 unassign=0
[    4.850409] ssv6x5x chanctx ops set but not complete
[    4.850424] Attach SSV6006 family HAL function
[    4.858285] MAC address from e-fuse
[    4.858311] EFUSE configuration
[    4.858315] Read efuse chip identity[79000000]
ip link show:
6: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DORMANT group default qlen 1000
    link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
Hello, congratulations for your achievement!
I wonder if you had the chance to give a shot to the ssv6051 sibling... the original drivers (one for ssv6051 and another for ssv6x5x) were really a mess that @ilmich and me did a lot of work at the time to cleanup and fix things in the past time. We concentrated against the ssv6051 driver at the time and in fact the ssv6051 driver already works in mainline kernel (it is in the rockchip 32bit patch directory), although it is still quite a mess. Here it is the repository if you want to take a look to the commits.
We also started an attempt to do a clean and proper reimplementation of the ssv6xxx driver, but actually never went over firmware loading (the repo is private since it was a heavy WIP, but can share if you have enough will to take a look to that)
Posted (edited)
@Kevin su Excellent work! Porting the SV6256P driver all the way to kernel 6.12 is a huge achievement. Most users usually just give up and plug in a USB Wi-Fi adapter to avoid the headache of legacy drivers.
Edited by Nick A
@jock
The driver-related knowledge is vast and quite complicated, with many pitfalls, so porting really requires strong assistance from AI.
I don’t have an SSV6051, so I can’t actually complete the porting myself.
Btw, the "ssv6x5x-sw.bin" I’m using is the file you posted on the forum.
@Nick A Yes, I used the MT7601U for a few days, but I wasn’t really satisfied with it. So, with the help of AI, I decided to port the SV6256P anyway—and to my surprise, it actually worked.
While reviewing the system logs, I noticed several ftrace warnings appearing in dmesg.
After investigating the root cause, I have applied the necessary configuration updates to eliminate these logs.
The driver is now running cleanly without any ftrace-related noise.
Hey guys and @jock. Thanks for the references.
not very fast, but stable and working on a s905w. (guess to be a tx3 mini, but who knows...)
kernel 6.18.10 and ssv6051p.
Linux aml-s9xx-box 6.18.10-current-meson64 #3 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 aarch64 GNU/Linux
with speedtest-cli
Download: 3.43 Mbit/s
Upload: 1.55 Mbit/s
yeah, slow. but stable... i guess
dmesg
[   11.938463] SSV WLAN driver ssv6200: chip id: RSV6200A0-201311, tag: 2014012420010960
[   12.006600] SSV WLAN driver ssv6200: attempt to load firmware ssv6051-sw.bin
[   12.021645] SSV WLAN driver ssv6200: firmware upload complete (wrote 80 blocks, verified 80 blocks)
[   12.138546] SSV WLAN driver ssv6200: Firmware version 16380
[   12.141013] SSV WLAN driver ssv6200: Calibration successful
https://github.com/eloirotava/6051
the repo has also the rtl8188fu driver to the same soc/kernel. it is better than the ssv for sure...
The trick was tuning the ssv6051-wifi.cfg to disableHT/AMPDU that usually kill the SDIO bus on these SOCs.
I ran a speed test on my SSV6051. Here are the results:
Idle Latency:     9.78 ms   (jitter: 1.12ms, low: 9.33ms, high: 10.93ms)
    Download:    34.46 Mbps (data used: 23.6 MB)
                 52.01 ms   (jitter: 6.52ms, low: 19.97ms, high: 109.64ms)
      Upload:     8.25 Mbps (data used: 12.4 MB)
                 99.47 ms   (jitter: 26.37ms, low: 48.84ms, high: 491.13ms)
 Packet Loss:     0.0%
@Kauã Fonseca
There are SSH commands in my GitHub repository. Just SSH into your TV box and execute them one by one.
sudo apt-get update
sudo apt-get install -y build-essential linux-headers-$(uname -r) git
git clone https://github.com/cdhigh/armbian_sv6256p.git
cd armbian_sv6256p
chmod +x ./parser-conf.sh
make ARCH=arm64 KSRC=/lib/modules/$(uname -r)/build
ls -lh ssv6x5x.ko
sudo cp ./ssv6x5x-wifi.cfg /lib/firmware/
sudo cp ./ssv6x5x-sw.bin /lib/firmware/
sudo cp ./ssv6x5x.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/
sudo depmod -a
sudo modprobe ssv6x5x
ip link show
nmtui
