M.E. B. Posted February 15 Posted February 15 the tft is working well on stock orangepi image but when I try the prebuilt armbian images or build it myself it look like this my dts file: 35Lcd.dts 0 Quote
robertoj Posted February 20 Posted February 20 (edited) Make sure you have ili9486.ko in your ko module folder: modinfo ili9486 Can you use the DTS that I published in: https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-208446 But change the "compatible" line with waveshare,rpi-lcd-35 , Delete the stuff under the "compatible" line, until the "}vsync-len = <0>;", and replace it with what you had in your DTS. Change these lines, if they are different: spi-max-frequency = <24000000>; rotate = <270>; bgr; fps = <30>; buswidth = <8>; regwidth = <16>; Reference: https://github.com/raspberrypi/linux/blob/rpi-6.12.y/arch/arm/boot/dts/overlays/piscreen-overlay.dts Edited February 20 by robertoj 0 Quote
Fabio Coroli Posted February 26 Posted February 26 How do you make it work on the original OS? I have the same screen and the same Orange Pi, but I haven't been able to make it work. 0 Quote
robertoj Posted February 26 Posted February 26 Maybe this comment and thread have a hint for you https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-229274 I don't own a waveshare LCD... but I would also like to know if its possible to make it work with Armbian 0 Quote
