OPI PC+ not booting on eMMC (internal 8GB) since...
just registered on this forum because i can't troubleshoot my issue even if some posts seems to look like my issue and this forum doesn't unknown from me from some others reasons.
Orange PI pc plus
OpenELEC-H3.arm-7.0-devel-20161026221641-r23113-g64b34b3-opipcplus.img
on eMMC since few months.
After successfully make (for USB support) and tested 'u-boot-sunxi-with-spl.bin' on my SD card, i decided to write it onto the eMMC after booting from SD card with this kind of command:
dd if=./u-boot-sunxi-with-spl.bin of=/dev/mmcblk0 bs=1024 seek=8
now i have this output (from UART) see bellow
thanks in advance for help
Philip63
--console output--
compilation 'u-boot-sunxi-with-spl.bin' OK
boot depuis SD pour upgrade u-boot + SPL sur eMMC (pour prise en compte USB)
test sur SD = OK :
dd if=./u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8
mais depuis cette commande impossible de booter a partir de eMMC:
pas de SD inseree
sous console UART:
U-Boot SPL 2017.11-00391-g34dd853 (Nov 30 2017 - 19:51:13)           < la date de ma compilation
DRAM: 1024 MiB
Trying to boot from MMC2
U-Boot 2017.11-00391-g34dd853 (Nov 30 2017 - 19:51:13 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC Plus
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
Hit any key to stop autoboot:  0
=> version
arm-linux-gnueabihf-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
GNU ld (GNU Binutils for Ubuntu) 2.26.1
=> mmc list
SUNXI SD/MMC: 0
SUNXI SD/MMC: 1 (eMMC)
=> mmc dev
switch to partitions #0, OK
mmc1(part 0) is current device
=> mmc list
SUNXI SD/MMC: 0
=> mmc part
Partition Map for MMC device 1  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
  1     2048            1048577         6b6009a0-01     0c Boot
  2     1052672         14217216        6b6009a0-02     83
=> fatls mmc 1:1
  6234464   KERNEL
 134189056   SYSTEM
    32276   script.bin
      295   boot.scr
            eMMC-8GB-internal/     < un flag pour etre sur
4 file(s), 1 dir(s)
=> ext2ls mmc 1:2
<DIR>       1024 .
<DIR>       1024 ..
<DIR>      12288 lost+found
<DIR>       1024 .kodi
<DIR>       1024 music
<DIR>       1024 pictures
<DIR>       1024 tvshows
<DIR>       1024 videos
<DIR>       1024 screenshots
<DIR>       1024 .update
<DIR>       1024 .cache
<DIR>       1024 .config
<DIR>       1024 .ssh
<DIR>       1024 .smb
<DIR>       1024 mnt
            2726 .ash_history
<DIR>       1024 .dvdcss
        20706289 gadgetmodulekernel_151226a.tgz
<DIR>       1024 tmp
            8192 fel-sdboot.sunxi
=> mmc info
Device: SUNXI SD/MMC
Manufacturer ID: 15
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 512 KiB ENH
trace:
=> reset
resetting ...
DRAM: 1024 MiB
DRAM:  1 GiB
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
MMC: no card present
mmc_init: -123, time 2
Scanning mmc 1:1...
Found U-Boot script /boot.scr
reading /boot.scr
295 bytes read in 14 ms (20.5 KiB/s)
** Bad device mmc 0 **
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
*******************************TEST*******************************
BOOTP broadcast 1
*** Unhandled DHCP Option in OFFER/ACK: 125
This commit sunxi: remove MMC index hack made between v2017.09 and v2017.11 changed the logic for numbering SD/MMC devices, so older boot scripts that used "mmc 0" in all commands are breaking on upgrade.
For the reference this will affect Armbian too - that's why I held the u-boot version for this (Armbian 5.25) stable release at 2017.09.
first, thanks for reply
before:
=> mmc rescan
=> mmc list
SUNXI SD/MMC: 1
SUNXI SD/MMC: 0 (eMMC)
=> mmc info
Manufacturer ID: 15
OEM: 100
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
=> part list mmc 0
Partition Map for MMC device 0  --   Partition Type: DOS
=> fstype mmc 0:1
fat
=> fstype mmc 0:2
ext4
after;
=> mmc rescan
=> mmc list
SUNXI SD/MMC: 0
=> mmc info
Manufacturer ID: 15
OEM: 100
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
=> part list mmc 0
mmc_init: -123, time 1
=> fstype mmc 0:1
=> fstype mmc 1:1
fat
=> fstype mmc 1:2
ext4
i dont understood all what to do but
is there something possible to do from u-boot prompt?
thanks
Yes. If you know how your boot script looks like you can enter commands manually (substituting "mmc 0" with "mmc 1") to boot the OS and replace the u-boot or boot script from there or you can boot a different OS from SD to access the eMMC.
Hi Zador,
and there is a way to display boot.scr contents from u-boot prompt?
Edited by Philip63
relolved
retrieve an recent output (hope it is the good one):
setenv machid 1029
setenv bootm_boot_mode sec
#setenv bootargs console=ttyS0,115200 boot=/dev/mmcblk1p1 disk=/dev/mmcblk1p2 consoleblank=0
fatload mmc 0 0x43000000 script.bin
fatload mmc 0 0x42000000 KERNEL
bootm 0x42000000
Edited by Philip63
resolved
=> load mmc 1:1 0x5000000 boot.scr
reading boot.scr
=> md 0x5000000
05000000: 00000000 00000000 00000000 00000000    ................
05000010: 00000000 00000000 00000000 00000000    ................
05000020: 00000000 00000000 00000000 00000000    ................
05000030: 00000000 00000000 00000000 00000000    ................
05000040: 00000000 00000000 00000000 00000000    ................
05000050: 00000000 00000000 00000000 00000000    ................
05000060: 00000000 00000000 00000000 00000000    ................
05000070: 00000000 00000000 00000000 00000000    ................
05000080: 00000000 00000000 00000000 00000000    ................
05000090: 00000000 00000000 00000000 00000000    ................
050000a0: 00000000 00000000 00000000 00000000    ................
050000b0: 00000000 00000000 00000000 00000000    ................
050000c0: 00000000 00000000 00000000 00000000    ................
050000d0: 00000000 00000000 00000000 00000000    ................
050000e0: 00000000 00000000 00000000 00000000    ................
050000f0: 00000000 00000000 00000000 00000000    ................
Edited by Philip63
removed
my question;
your answer:
now (tomorow morning) , what can i do please
thanks
Edited by Philip63
hello there,
according with zador advices,
i tried to build an boot.scr (with mkimage) with 'mmc 1' instead of 'mmc 0' but boot from eMMC fail anyway.
output:
DRAM: 1024 MiB
DRAM:  1 GiB
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
Scanning mmc 1:1...
reading /boot.scr
378 bytes read in 15 ms (24.4 KiB/s)
 **Unable to read file script.bin                            <  fatload mmc 1 0x43000000 script.bin
from /boot.scr
 **Unable to read file KERNEL                              < fatload mmc 1 0x42000000 KERNEL from /boot.scr
bootm - boot application image from memory
Usage:
bootm [addr [arg ...]]
but from u-boot prompt (and then i dont understand at all) it seem to be okay but bootm fail and resetting...
=> fatload mmc 1 0x43000000 script.bin
reading script.bin
32276 bytes read in 25 ms (1.2 MiB/s)
=> imi 0x43000000
## Checking Image at 43000000 ...
Unknown image format!
=> fatload mmc 1 0x42000000 KERNEL
reading KERNEL
6234464 bytes read in 294 ms (20.2 MiB/s)
=> imi
## Checking Image at 43200000 ...
=> imi 0x42000000
## Checking Image at 42000000 ...
   Legacy image found
   Image Name:   Linux-3.4.113
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    6234400 Bytes = 5.9 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
=> bootm 0x42000000
## Booting kernel from Legacy Image at 42000000 ...
   Loading Kernel Image ... OK
resetting ...
DRAM: 1024 MiB
any idea ?
thanks
Edited by Philip63
resolved with other u-boot-sunxi-with-spl.bin
