Newbie on Armbian.
I have an Allwinner H313 (confirmed) box that I want to to use as a basic Samba server.
 CPU:Allwinner H313Quad Core ARM Cortex A53
 GPU:Mali-G31 OPenGL ES3.2
 Memory:2GB
 Flash:16GB
 OS:Android 10.0
The actual firmware is a secure image and, no matter what procedure I do, I can't  load any other image but
the secure one.
Debugging shows that 'fastbootd' has the "secure" flag set.
My intention is to create a  basic secure arm64 Debian image but I am having a hard time in doing so.
Any ideas (specific Wiki, procedures) on how to create the secure image or "reset" the "secure" flag will be very appreciated.
Thanks in advance.
On a first analysis, I noticed that the git already has a very similar option that I need (H313):
~/build/patch/u-boot/u-boot-sunxi/board_x96q$
   arm64-sun50i-h313-add-x96q-lpddr3-defconfig.patch
   sunsi-add-h616-internal-eth-phy-support.patch
so I am stuck on how to proceed because the example has H616 parameters.
Help will be appreciated.
Posted (edited)
@Sergioclr the H313, H616, H618, and IK316 are essentially the same SoC family. To successfully boot an image, you must match the correct AXP chip (the Power Management IC) and the specific DRAM version used on your board.
Essentially, any thread discussing the H616/H618 (excluding older H3/H5/H6 chips) will contain relevant information for these SoCs.
PMIC Information:
http://linux-sunxi.org/AXP_PMICs
DRAM Types:
3: DDR3
4: DDR4
7: LPDDR3
8: LPDDR4
You can try flashing various boot images until one successfully initializes your hardware. (If your box is secure-boot enabled, you will need to add the secure-boot modifications posted above.)
https://github.com/NickAlilovic/build/releases/tag/20250306
Alternatively, for a more precise approach:
Extract your Device Tree (DTS).
Identify the specific AXP chip located on your board.
Connect a USB-to-UART TTL device to the RX, TX, and GND pins on your board to monitor the boot sequence.
https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-232411
https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/4/#findComment-187672
https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/23/#findComment-218660
https://docs.radxa.com/en/rock5/rock5itx/radxa-os/serial?os=windows
https://linux-sunxi.org/UART
https://www.amazon.ca/IZOKEE-CP2102-Converter-Adapter-Downloader/dp/B07D6LLX19/ref=sr_1_2_mod_primary_new
Decompile your Device Tree Blob (DTB😞
dtc -I dtb -O dts -o source.dts source.dtb
For a visual reference of a board using these specific chips, check out this hardware breakdown.
http://nskhuman.ru/allwinner/krugh618.php?np=3
Edited by Nick A
$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 13 (trixie)"
NAME="Debian GNU/Linux"
VERSION_ID="13"
VERSION="13 (trixie)"
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.4
Compile phase failed due to missing package (ntpdate)
Short log:
[🌱] Configuration prepared for BOARD build [ x98h.csc ]
[] Repeat Build Options (early) [ ./compile.sh build BOARD=x98h BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=trixie ]
[🌱] Checked directory OK for mount options [ /home/*****/build/.tmp ('main temporary dir') ]
[🌱] Preparing [ host ]
[🌱] Python2 not available on host release 'trixie' [ ancient u-boot versions might/will fail to build ]
[🌱] Updating apt host-side for installing host-side packages [ 50 packages ]
[🌱] Installing host-side packages [ binfmt-support bison libc6-dev make dpkg-dev gcc ccache device-tree-compiler dwarves flex imagemagick jq libbison-dev libelf-dev libfdt-dev libfile-fcntllock-perl libmpc-dev libfl-dev lz4 libncurses-dev libssl-dev libusb-1.0-0-dev ntpdate patchutils pkg-config pv qemu-user-static arch-test swig u-boot-tools uuid-dev zlib1g-dev expect colorized-logs zip pigz pbzip2 lzop gdisk aria2 axel parallel rdfind libpython3-dev libffi-dev libgnutls28-dev gcc-aarch64-linux-gnu libc6-amd64-cross gcc-arm-linux-gnueabi gcc-or1k-elf ]
[🔨]   E: Package 'ntpdate' has no installation candidate
[💥] error! [ Failed to install host packages; make sure you have a sane sources.list.  ]
[💥] Cleaning up [ please wait for cleanups to finish ]
[🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-dd186c47-e7eb-49f8-8d38-836915cf0aec.log.ans ]
[🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ]
Note
ntpdate has a more recent version: ntpsec-ntpdate
Should I try to compile in a Debian 12 computer? I am afraid of messing with 'sources.list'.
Thanks in advance.
@Sergioclr
Requirements for self hosted
x86_64 / aarch64 machine
at least 2GB of memory and ~35GB of disk space for VM, container or bare metal installation
Armbian / Ubuntu Jammy 22.04.x for native building or any Docker capable Linux for containerised
Windows 10/11 with WSL2 subsystem running Ubuntu Jammy 22.04.x
Superuser rights (configured sudo or root access).
Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble.
Posted (edited)
Update: I was able to compile the H98H example and write it to SD card (Armbian Imager).
The SD firmware load promptly "bricked" the box!
I reloaded the original (secure) image by means of PhoenixSuit software.
I am considering building an image using  sun50i-h313-x96q-ddr3-v5.1.dts but I don't know how to customize the "@@ -0,0 +1,162 @@"
parameters.
Could you help me?
Thanks in advance.
Edited by Sergioclr
choice of words
Posted (edited)
@Sergioclr can you find a AXP chip on your board? It’s safer to boot images with the same AXP chip. I haven’t bricked any of my boxes. Don’t use armbian-config’s write to emmc until you have a stable image.
Edited by Nick A
After compiling many (10+) images, I was not able to boot a single one through SD card and the "toothpick" technique. It is not my character, but I give up.
I am grateful for your support and patience.
Thank you. Sergioclr.
Posted (edited)
Debug (Phoenixsuit) original software loaded (emmc)
Photo from TV Box recovery menu:
Thanks in advance.
Edited by Sergioclr
remove question
@Sergioclr Those unpopulated pads in the top-left corner are likely the UART (Serial) debug port.
Check the underside of the board—are the pads labeled GND, TX, and RX there? The most reliable way to boot Linux on this box is to use a USB-to-UART TTL adapter. Without one, we’re essentially working blind.
Yes, the pads are marked GND, TX and RX (underside)!
I have an old USB-to-serial (DB9) cable adapter (PL2303HXA), will it work or I have to buy one like this?
Question regarding to a post of yours:
"Your root_key.pem needs to be in the u-boot root directory"
As per instructions, I created the secure-boot.patch in ~/build/patch/u-boot/u-boot-aw
but there is no  root_key.pem in the u-boot root directory.
Posted (edited)
@Sergioclr Search the forums for "PL2303HXA". I think it will work.
After you compile your build, check build/cache/sources/u-boot-worktree/u-boot*; you should find root_key.pem there
Edited by Nick A
Posted (edited)
@Sergioclr Well that is the u-boot root directory. Where the main Makefile is located. I added my own root_key.pem in the patch. You don't have to generate one.
The root_key.pem for Allwinner H616/618/313 devices is not a single, universal file, but rather an RSA private key file used for signing bootloader images (TOC0) in secure boot implementations. In many commercial H616-based TV boxes, Secure Boot is enabled by the manufacturer, but the efuses (which store the root key hash) are not permanently locked, allowing the use of custom keys
openssl genrsa -out root_key.pem
Edited by Nick A
Posted (edited)
Good afternoon.
image X96Q LPDDR3 (w/ secure-boot patch) sucessfully compiled (Min22 XFCE, Trixie packages);
UART installed, image boots OK, wlan0 IP address defined.
Problems:
apt update fails (error) to install armbian-firmware_26.2.1_all.deb
box ethernet port is not recognized
The following is a screen capture of Putty (serial via UART) of the system:
Any suggestions?
Thanks in advance.
Edited by Sergioclr
Good morning.
Results (link above):
1) Image built upon the above link=fail
2) Placing  "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" in ~/build/patch/u-boot/u-boot-sunxi/board_x96q/arm64-sun1-h313-addr-x96q-lpddr3-defconfig.patch , adding secure-boot.patch and
    ~/build/patch/u-boot/u-boot-sunxi/board_x96q/sunsi-add-h616-internal-eth-phy-support.patch left untouched  equals successful boot but, still, no ethernet
Thanks in advance.
