Sergioclr Posted April 22 Author Posted April 22 (edited) Activity: 1) 159-add-x96-q-lpddr3-v1.3-defconfig.patch has been tested both ways: with original parameters and with suggested (above) parameters; 2) The box boots but I am unable to set IP addresses, even in wlan0, via Armbian-config (errors reported); 3) So far the best result is from ~/build/patch/u-boot/u-boot-sunxi/board_x96q/arm64-sun50i-h313-add-x96q-lpddr3-defconfig.patch with the appropriate +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y and secure-boot.patch. Armbian-config works as designed and IP addresses can be set. Ideas: describes a similar problem (eth0) Suggested action plan: https://github.com/armbian/build/pull/6617/files [Fix issue #6528 opi-zero2w, ethernet PHY not powered #6617] Problem: I don't know how to implement it and/or if that proposed corrections will tamper with ~/build/patch/u-boot/u-boot-sunxi/board_x96q/sunsi-add-h616-internal-eth-phy-support.patch As usual, suggestions will be welcome 🙂 Edited April 22 by Sergioclr link 0 Quote
Nick A Posted April 22 Posted April 22 (edited) @Sergioclr You don't need patches to edit the kernel config: config/kernel/linux-sunxi64-legacy.config sicxnull already has this patch, but with a different name: drv-pwm-sun50i-h616-enhance-pwm.patch drivers-pwm-Add-pwm-sunxi-enhance-driver-for-h616.patch To add Zero2W Ethernet settings to your DTS, you can create your own patch using git commands: Run ./compile.sh Press Ctrl+C in the middle of the kernel compilation. Navigate to the directory: cd cache/sources/linux-kernel-worktree/6.6*/ Use the following commands: sudo git status sudo git add . sudo git commit -m "dummypatch" sudo pico arch/arm64/boot/dts/allwinner/sun50i-h313-x96q-lpddr3.dts sudo git add . sudo git commit -m "Fix Ethernet" sudo git format-patch -1 1 for the first commit (0001-Fix-Ethernet.patch)... 2 for the first and second commit (0002-dummypatch.patch) ) The first "add" and "commit" cleans the kernel of previous patches, leaving you with a clean, patched kernel. The format-patch command will create a patch in the root directory of the kernel. Copy it to your patch directory. For original Armbian kernel patches, you must add them to series.armbian and series.conf. Edited April 22 by Nick A 0 Quote
Sergioclr Posted April 24 Author Posted April 24 Help needed (previous update): What should be edited is this file? sudo pico arch/arm64/boot/dts/allwinner/sun50i-h313-x96q-lpddr3.dts Thanks in advance. 0 Quote
Nick A Posted April 24 Posted April 24 (edited) @Sergioclr Can you post your boot logs? both android and armbian. Try this. phy-supply = <®_dldo1>; /* Try reg_dldo1 if aldo1 (1.8V) fails */ Edited April 24 by Nick A 0 Quote
Sergioclr Posted April 24 Author Posted April 24 Newbie question: how can I do that (boot logs)? 🤔 0 Quote
Sergioclr Posted April 26 Author Posted April 26 Good evening. Armbian for H313 X96-Q LPDDR3 TV-Box sicXnull/armbian-build) git clone --depth=1 --branch=main https://github.com/armbian/build "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" in ~/build/patch/u-boot/u-boot-sunxi/board_x96q/arm64-sun1-h313-addr-x96q-lpddr3-defconfig.patch , adding secure-boot.patch and ~/build/patch/u-boot/u-boot-sunxi/board_x96q/sunsi-add-h616-internal-eth-phy-support.patch left untouched Android-boot.txt (normal boot sequence / eth & wlan=OK) Armbian_image_reboot_dmesg.txt Image reboot (sudo shutdown -r now) + dmesg log (wlan=OK, eth=not OK) Thanks in advance. Android-boot.txt Armbian_image_reboot_dmesg.txt 0 Quote
Nick A Posted April 26 Posted April 26 @Sergioclr looks like you are building armbian main branch. You are running the 6.18 kernel but old u-boot 2024.01. I don’t see the AC200/300 patch. Do you still have my build laying around. Can you show me the boot logs. 0 Quote
Sergioclr Posted April 26 Author Posted April 26 No, unfortunately, I don't have. I will run your build and, possibly, have all required data by tomorrow morning. Thanks for your prompt answer, 0 Quote
Sergioclr Posted April 26 Author Posted April 26 Good morning. git clone https://github.com/NickAlilovic/build.git --branch v20251014 ~/build/patch-u-boot/u-boot-aw/150-1dd-x96q-lpddr3-defconfig.patch "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" ~/build/patch-u-boot/u-boot-aw/secure-boot.patch ./compile.sh choice = x96q-lpddr3 2026-04-26_0851h.txt boot sequence, shutdown -r and dmesg Thanks in advance. 2026-04-26_0851h.txt 0 Quote
Sergioclr Posted May 6 Author Posted May 6 Update: sicXnull/armbian-build (H96q) + "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and "secure-boot.patch" solved the problem. Now, the ethernet interface is fully functional. Thank you Nick & sicXnull. 0 Quote
Sergioclr Posted May 13 Author Posted May 13 Hi, I am assuming that you have a standard Q1 TV Box (Allwinner H313 based). 1) Download Armbian Imager here; 2) Install the version for your operating system; 3) After installing, choose "Manufacturer=ALLWINNER", Board="X96Q TV BOX", Operating system="minimal Trixie current" and Storage ( I suggest a good quality Class 10 SD card); 4) After writing the image, insert the SD card into the available SD slot; 5) Insert a wooden toothpick or a Q-tip into AV/Reset input; 6) Click (kindly) and hold the toothpick and connect the TV Box power supply to the power entry; 7) Release the toothpick after 8-10 seconds. if the HDMI connector is plugged you should see the Armbian initial boot process Note: some TV Boxes don't need items 5, 6 and 7. I hope it helps. 0 Quote
Thịnh Nguyễn Posted May 27 Posted May 27 no, it have secureboot, emcp 1,5gb instead 1 or 2gb ram, i tried to boot x96q lpddr3 + secure patch + orangepi zero3 1,5gb patch but at uboot it allway say 2gb ram 0g effective. uboot spl load 1,5gb ram correctly 0 Quote
Sergioclr Posted Thursday at 05:59 PM Author Posted Thursday at 05:59 PM Hi, I can suggest a general procedure but it is not guaranteed to work for every TV-Box. 1) Be sure of what TV-box you have (Allwinner, Ambian or Rockship); 2) download git clone --depth=1 --branch=main https://github.com/armbian/build 3) open downloaded git and search for /build/patch/u-boot 4) select the directory that corresponds to your TV-box. For example: /build/patch/u-boot/u-boot-sunxi 5) edit arm64-sun50i-H313-add-lpddr3-deconfig.patch, if you have a secure image: add +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y and increment the counter to 32 (@@ -0,0 +1,32 @@) and "secure-boot.patch" to /build/patch/u-boot/u-boot-sunxi. See procedure here https://forum.armbian.com/profile/210518-nick-a/ 6) ./compile.sh observing Nick's instructions. 0 Quote
Sergioclr Posted Thursday at 11:48 PM Author Posted Thursday at 11:48 PM (edited) Nick's instructions: You need to add this line to the bottom. "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and change "@@ -0,0 +1,31 @@" to @@ -0,0 +1,32 @@. ./compile.sh choose "Do not change kernel configuration" choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" choose "X98H" choose "edge" rest is up to you. Your image should be in output/images directory. Edited Thursday at 11:50 PM by Sergioclr clarification 0 Quote
nguyễn thịnh Posted 16 hours ago Posted 16 hours ago I already build a lot of images for another boards. My problem is uboot spl corrected 1536mb ram okay, but after that, it load uboot and say dram 2gb 0gb effective. Real ram is 1,5gb 0 Quote
Sergioclr Posted 1 hour ago Author Posted 1 hour ago Hi, my knowledge about Armbian is limited. For such a specific configuration/compilation I suggest that you open a new topic under "Allwinner sunxi". Best regards. 0 Quote
