Posted (edited)
Activity:
1) 159-add-x96-q-lpddr3-v1.3-defconfig.patch has been tested both ways: with original parameters and with suggested (above) parameters;
2) The box boots but I am unable to set  IP addresses, even in wlan0, via Armbian-config (errors reported);
3) So far the best result is from  ~/build/patch/u-boot/u-boot-sunxi/board_x96q/arm64-sun50i-h313-add-x96q-lpddr3-defconfig.patch with the appropriate +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y
    and secure-boot.patch. Armbian-config works as designed and IP addresses can be set.
Ideas
describes a similar problem (eth0)
Suggested action plan: https://github.com/armbian/build/pull/6617/files       [Fix issue #6528 opi-zero2w, ethernet PHY not powered #6617]
Problem: I don't know how to implement it and/or if that proposed corrections will tamper with ~/build/patch/u-boot/u-boot-sunxi/board_x96q/sunsi-add-h616-internal-eth-phy-support.patch
As usual, suggestions will be welcome 🙂
Edited by Sergioclr
link
Posted (edited)
@Sergioclr
You don't need patches to edit the kernel config:
config/kernel/linux-sunxi64-legacy.config
sicxnull already has this patch, but with a different name:
drv-pwm-sun50i-h616-enhance-pwm.patch
drivers-pwm-Add-pwm-sunxi-enhance-driver-for-h616.patch
To add Zero2W Ethernet settings to your DTS, you can create your own patch using git commands:
Run ./compile.sh
Press Ctrl+C in the middle of the kernel compilation.
Navigate to the directory:
cd cache/sources/linux-kernel-worktree/6.6*/
Use the following commands:
sudo git status
sudo git add .
sudo git commit -m "dummypatch"
sudo pico arch/arm64/boot/dts/allwinner/sun50i-h313-x96q-lpddr3.dts
sudo git add .
sudo git commit -m "Fix Ethernet"
sudo git format-patch -1
1 for the first commit (0001-Fix-Ethernet.patch)...  2 for the first and second commit (0002-dummypatch.patch) )
The first "add" and "commit" cleans the kernel of previous patches, leaving you with a clean, patched kernel.
The format-patch command will create a patch in the root directory of the kernel. Copy it to your patch directory.
For original Armbian kernel patches, you must add them to series.armbian and series.conf.
Edited by Nick A
Good evening.
sicXnull/armbian-build)
git clone --depth=1 --branch=main  https://github.com/armbian/build
"+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" in ~/build/patch/u-boot/u-boot-sunxi/board_x96q/arm64-sun1-h313-addr-x96q-lpddr3-defconfig.patch , adding secure-boot.patch and
    ~/build/patch/u-boot/u-boot-sunxi/board_x96q/sunsi-add-h616-internal-eth-phy-support.patch left untouched
Android-boot.txt  (normal boot sequence / eth & wlan=OK)
Armbian_image_reboot_dmesg.txt
Image reboot (sudo shutdown -r now) + dmesg log (wlan=OK, eth=not OK)
Thanks in advance.
Android-boot.txt Armbian_image_reboot_dmesg.txt
@Sergioclr looks like you are building armbian main branch. You are running the 6.18 kernel but old u-boot 2024.01. I don’t see the AC200/300 patch.
Do you still have my build laying around. Can you show me the boot logs.
No, unfortunately, I don't have.
I will run your build and, possibly, have all required data by tomorrow morning.
Thanks for your prompt answer,
