Hi,
I upgraded to the stable version of Debian (Trixie) Armbian Linux 6.18.23-current-rockchip64. And the USB 3.0 port stopped working. Other USB 2.0 works fine.
orangepi3b:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS578 SATA 6Gb/s
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
orangepi3b:~$ sudo dmesg|grep usb6
[    2.474823] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.18
[    2.474852] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.474867] usb usb6: Product: Generic Platform OHCI controller
[    2.474881] usb usb6: Manufacturer: Linux 6.18.23-current-rockchip64 ohci_hcd
[    2.474893] usb usb6: SerialNumber: fd840000.usb
orangepi3b:~$ sudo dmesg|grep usb7
[    2.416665] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.416917] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    2.416940] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.416956] usb usb7: Product: xHCI Host Controller
[    2.416969] usb usb7: Manufacturer: Linux 6.18.23-current-rockchip64 xhci-hcd
[    2.416983] usb usb7: SerialNumber: xhci-hcd.1.auto
[    5.223412] usb usb7-port1: connect-debounce failed
I am using the same board, and I also experienced this. Sometimes USB is not re-enumerated. Also, if you're using USB-C, sometimes some wires requires you to flip the connector. Basically some makers are cheaping out on cables, and they work only when you flip it.
Also, if you'll leave the drive connected and reboot, does it find it? Have you checked u-boot, does it see it?
Be aware, that USB-C connector is finicky. I had to replace it (resolder with new, sturdier variant), and then make it concrete-hard to break by solidifying epoxy over and under it (keep connector connected in it, and put some oil on it before plugging it in, so that epoxy won't leak inside it.
