Philip63 Posted December 16, 2017 Posted December 16, 2017 Hello, [OPI PC+] u-boot : boot.scr issue Oracle VM: Linux cross-compilation 4.10.0-42-generic #46~16.04.1-Ubuntu SMP Mon Dec 4 15:57:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux DS413J as DHCP and PXE/TFTP server with these files (copied from /dev/mmcblk0p1) on the TFTP root: boot.scr (mine but original one works well) script.bin KERNEL Same issue if i put my boot.scr onto the eMMC... Every single command works well on u-boot prompt. boot.cmd as follow, compiled with this command from Armbian doc: # OpenELEC Boot (philip63 - 02.12.2017) gpio set PL10 gpio set PA15 setenv machid 1029 setenv bootm_boot_mode sec setenv bootargs console=ttyS0,115200 boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 consoleblank=0 fatload mmc 0 0x43000000 script.bin fatload mmc 0 0x42000000 KERNEL bootm 0x42000000 philippe@cross-compilation:~/Documents/OPI/crosscompile/u-boot/tools$ mkimage -C none -A arm -T script -d ./boot.cmd ./boot.scr Image Name: Created: Sat Dec 16 11:09:10 2017 Image Type: ARM Linux Script (uncompressed) Data Size: 352 Bytes = 0.34 kB = 0.00 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 344 Bytes = 0.34 kB = 0.00 MB philippe@cross-compilation:~/Documents/OPI/crosscompile/u-boot/tools$ I have the following issue under u-boot with an boot.scr compiled from my own: U-Boot SPL 2017.09-armbian (Nov 22 2017 - 16:49:59) DRAM: 1024 MiB Trying to boot from MMC2 U-Boot 2017.09-armbian (Nov 22 2017 - 16:49:59 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus DRAM: 1 GiB MMC: SUNXI SD/MMC: 1, SUNXI SD/MMC: 0 In: serial Out: vidconsole Err: vidconsole Net: phy interface0 eth0: ethernet@1c30000 Autoboot in 5 seconds, press <Space> to stop => dhcp BOOTP broadcast 1 DHCP client bound to address 192.168.1.245 (62 ms) => tftp 0x43100000 boot.scr Using ethernet@1c30000 device TFTP from server 192.168.1.100; our IP address is 192.168.1.245 Filename 'boot.scr'. Load address: 0x43100000 Loading: # 406.3 KiB/s done Bytes transferred = 416 (1a0 hex) => source 0x43100000 ## Executing script at 43100000 ' not found Command 'gpio' failed: Error -22 ' not found Command 'gpio' failed: Error -22 reading script.bin **Unable to read file script.bin reading KERNEL **Unable to read file KERNEL bootm - boot application image from memory Usage: .../... Thanks in advance. Philippe
