HO Kin Chung Posted 2 hours ago Posted 2 hours ago Why doesn’t it start automatically after I log out or reboot after installation? What is causing this issue? The official Orange Pi kernel version (Orangepizero3_1.0.4_debian_bookworm_desktop_xfce_linux6.1.31) does not have this problem and runs automatically. Instead, I get the error: “dbus can't connect to fcitx5.” Every time I need to open the fcitx5 settings again and click “Run” before I can input Chinese. I have no idea what is going on. Thanks. 0 Quote
bedna Posted 52 minutes ago Posted 52 minutes ago (edited) More information is needed. What armbian release do you use? How did you install fcitx5? Have you followed the instructions on their wiki? https://fcitx-im.org/wiki/Special:MyLanguage/Setup_Fcitx_5 Or read the FAQ? https://fcitx-im.org/wiki/Special:MyLanguage/FAQ Are you using a chromium based browser? Quote Chromium or any other chromium based browser (E.g. Microsoft Edge) For Chromium running under X11, if you are using startx to start your graphical user interface, you may hit an issue in startx that unset the DBUS_SESSION_BUS_ADDRESS, which prevent chromium based browser from using dbus correctly. Edited 51 minutes ago by bedna 0 Quote
