Pieter van Leuven Posted June 10 Posted June 10 (edited) I managed to start de A5E from nvme, but upgrading the packages fails. Installing armbian-firmware_26.8.0-trunk.125_all.deb failed With: data.tar lzma error.... Several months ago I got the same error but ignored it. Now everything is almost working, I tried to find out what went wrong. I can extract package with dpkg-deb -x on another system. MD5sum is the same on A5E and other system. This problem occurs on sdcard and nvme card. Btw: it is the 4G version of the A5E. Any idea how I can solve this? Edited June 10 by Pieter van Leuven 0 Quote
Pieter van Leuven Posted June 26 Author Posted June 26 I ran memtester and found memorie errors, which is probably the cause of the problem I report med earlies. Hopefully this can be solved by changing voltage er timing settings. 0 Quote
