Folaht Pjehrsohmehj Posted June 19 Posted June 19 (edited) Armbianmonitor: https://paste.armbian.com/kabuhawuve I just installed Armbian for the first time. I tried the Trixie-current-minimal at first, but that didn't want to start for whatever reason. Should I try installing an Ubuntu one? I'm clueless. [edit] I managed to get Trixie-current-minimal working. Same issue. Edited June 19 by Folaht Pjehrsohmehj 0 Quote
eselarm Posted June 20 Posted June 20 I see several time the following log line: rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x2 I do not know what it means, but the fact that is is listed quite often is a hint I would say. There is also an earlier failure w.r.t. PCIE Usually is it power of some incompatibility of the NVME SSD in conjunction with the RK3588 based board. OrangePi5 Pro has questionable device-tree support, that is what I remember. It might be better nowadays, but I guess you will need to try an see if you can get any OS working/recognizing the SSD. 0 Quote
Folaht Pjehrsohmehj Posted June 22 Author Posted June 22 I've tried Ubuntu-gnome. Still no SSD recognition. 0 Quote
eselarm Posted June 22 Posted June 22 ubuntu nor gnome is not relevant what matters is u-boot and kernel (and powersupply and type of nvme ssd ) u-boot logs can be seen via serial console cable 0 Quote
Folaht Pjehrsohmehj Posted June 22 Author Posted June 22 (edited) Power supply: WNB-0504000 5V 4A 20W USB-C. SSD: Intenso Top Performance M.2 128GB SATA-600 I'm gonna buy a new power supply. Looks like I'm needing a 5A one. Edited June 22 by Folaht Pjehrsohmehj 0 Quote
Solution eselarm Posted June 22 Solution Posted June 22 (edited) 1 hour ago, Folaht Pjehrsohmehj said: SD: Intenso Top Performance M.2 128GB SATA-600 This is not NVME, but SATA. No surprise it does not work. It might be that the M.2 slot of the OPi5pro is such that with an overlay, you could map SATA signals to that slot and then it should work. Look in rockchip overlays folder for any .dtbo file with name like *rk3588*sata* But you should check HW circuit diagram maybe first, might also be that this is only for the normal OPi5 Maybe search a bit, I found Is old topic, but the principles are still the same. Edited June 22 by eselarm 0 Quote
Folaht Pjehrsohmehj Posted July 1 Author Posted July 1 I bought an NVMe SSD and it is being recognized. 0 Quote
