Posted (edited)
How can we acces the SPI NOR Flash on Odroid HC4?
The usual error
seems to be the driver, not a thing we can overlay device tree? Id for xt25f128b is implemented.
Zitat
unrecognized JEDEC id 0
meson-spifc ffd14000.spi: registered host spi0
spi spi0.0: setup mode 0, 8 bits/w, 1000000 Hz max --> 0
spi-nor spi0.0: supply vcc not found, using dummy regulator
spi-nor spi0.0: error -95 reading JEDEC ID
spi-nor spi0.0: probe with driver spi-nor failed with error -95
meson-spifc ffd14000.spi: registered child spi0.0
Edited by duing
Posted (edited)
I tried different overlays, reduced max-frequency, set rx-(-tx)-bus-width and different mode settings indepently. Is it perhaps driven by gpio regulator instead of fixed 3v3? With a vcc-supply property one line (warning) goes away.
Edited by duing
Posted (edited)
I wanted to play with: kernel on ubifs or perhaps DAX on erofs.
The bootloader must be signed differently for SD and NOR flash with some kind of arm-trusted-firmware, a PC binary that can be started as binmisc under qemu in Linux on ARM.
Edited by duing
Posted (edited)
How do you write U-Boot to SPI NOR flash?
Without a working driver upstream, the best I can think of now is just using the shipped U-Boot/Linux (Petitboot from the manufactor). If you want to make it from source, use the shipped cross-compiler on 64 bit PC, perhaps on an archived OS, or rewrite Makefiles.
But that leaves the (for some tiny) 16 MB just for the bootloader, which doesn't even knows it's own bootdev. It seems the beforehand bootloader-loader doesn't look after SATA HDD, only SPI NOR or MMC SD. After all, just press a button to alternately load from removable card if one installed and failed to run from NOR.
Did I miss a thing in device-tree? The regulator.patch is upstream, which keeps the drives spun-up while boot (at least MMC is powered).
Thanks, yours duing.
Edited by duing
Usually I do that via the U-Boot console, since I build my firmware with SPI command support for devices with SPI flash.
With an added convenience command, it's just a "==> run mmc-fw-to-sf" to transfer firmware currently running from microSD.
So everything is self-contained, no external components involved.
Posted (edited)
Am 29.6.2026 um 20:04 schrieb usual user:
I build my firmware [...] run mmc-fw-to-sf
You're using Hardkernel's U-Boot. Yes, it's probably more importent to read from flash memory early, at boot. Using the manufactors bootloader is the only option until the chip or whatever is supported "mainline".
If one doesn't care about flash, but doesn't want to depend on SD card to boot from e.g. SATA, an option is to run Hardkernel's Linux, once to write U-Boot to NOR flash . kexec seems to need CONFIG_PROC_KCORE, but Armbian as many others doesn't. Mainline U-Boot doesn't load Hardkernel's Linux. Perhaps just boot the spiupdate.img without spiboot.img and run. (sounds strange I know, but better than cross-cross-compile out-of-date)
Any news on mainline (patched) support for SPI NOR flash on Odroid-HC4? Perhaps I miss just a simple thing?
Edited by duing
Nope, my build is based on current mainline and even build on target (aarch64). I.e. no cross-compiling involved.
Oh, by the way, in my build  bootstd scans any attached storage for a valid bootflow and uses the first found one.
The used hardware interface dosen't matter and even network is valid.
Posted (edited)
vor 13 Stunden schrieb usual user:
ok, me too is not booting its first. is my hc4 flash chip newer? i think i tried all, mine is not initialized (petitboot said xt25f128b).
you said just `run mmc-to-sf`, that is not a mainline v2026-04 standard set variable, brother.
Thank you for your answer. I cannot access flash from mainline U-Boot nor Linux.
Edited by duing
As long as you do not provide proper serial console logs, no one can tell what is going on.
I can't help you in this situation any further, and you have to find a solution for yourself.
Posted (edited)
I followed your link and tried your build, nice menu but same error:
jedec_spi_nor flash@0: unrecognized JEDEC id bytes: 00, 00, 00
Failed to initialize SPI flash at 0:0 (error -2)
This error is from U-Boot and Linux gives the same, my first post shows the error in Linux with debugging turned on and a reduced frequency (and vcc-supply) set in device tree source.
It works with Hardkernel's firmware, thus is not a faulty hardware and nothing new.
Edited by duing
Posted (edited)
No, same error. We prefer to see the replicateable changes instead of running a wild binary.
Does it work for you on real Odroid-HC4 hardware? U-Boot prints (use CONFIG_DISPLAY_BOARDINFO_LATE):
SoC: Amlogic Meson SM1 (S905X3) Revision 2b:c (10:2)
Edited by duing
Your previous post reminded me that the board supplier changed the BOM of the ODROID-N2+ by using a different SPI flash vendor. He hacked the support for it into his legacy firmware build without making any further note about it. It took some effort of reverse engineering to figure that out. Mainline hasn't picked up this additional driver activation to this day, but I still keep it in my builds anyway.
In my latest build for the ODROID-HC4, I also included this driver to see if they might have gone about it in the same way. But your confirmation shows that this is probably not the case.
Since I don't have an ODROId-HC4 with the behavior you described on hand, I can't analyze any further what the cause of it is. These days, I also mostly avoid devices with Amlogic SoCs because of their strict closed-source policy and lack of mainline support. And the board manufacturer isn't much more helpful on this point either. Devices powered by Rockchip are much more appealing objects. So you have to help yourself if you want to find a solution.
Posted (edited)
I compiled Linux from hardkernel–it works with the devicetree from petitboot firmware. There's a emmc-data-4b node (not in their source code) which does:
&emmc_conf_pull_up {
    mux {
        drive-strength = <3>;
        groups = "emmc_nand_d0", "emmc_nand_d1", "emmc_nand_d2", "emmc_nand_d3";
        function = "emmc";
        input-enable;
        bias-pull-up;
Trying this with mainline e.g. overlay=g12b-odroid-n2-spi isn't enough here.
No option to wakeup (ir, lan, keyboard) is another reason to stick with 4.9.
Edited by duing
That's the advantage when you use a device that doesn't have a PMIC and only goes into deep sleep mode for Off Mode.
This is only supported by the proprietary, closed-source manufacturer firmware, for which of course no publicly available API description exists.
Mainline support will therefore most likely not become available. So it basically just leaves reverse engineering and an out-of-tree implementation.
Good luck.
Posted (edited)
shit. no. of course go mainline if ou can. i even hate systemd.
the best i can think of now (not tried yet) is first booting 4.9 to set wakeup if poweroff, then kexec to mainline (but shipped firmware doesn't). i just have wake-on-lan working here.
cramfs is obsolent but cool, why uboot loads it? linux can mount it (instead of initramfs, as it could use the 5mb unset with the factory partition table).
to quickly setup a cute rootfs, just run:
os=/mnt
pkg=busybox-binsh
if [ ! -f /sbin/apk ]; then
    service=http://edge.kernel.org
    arch=aarch64
    branch=v3.24
    version=3.0.6-r0
    wget -T 2 $service/alpine/$branch/main/$arch/apk-tools-static-$version.apk -O - |tar -xzf - -C $os sbin/apk.static
    /mnt/sbin/apk.static -X $service/alpine/edge/main/ -U --allow-untrusted -p $os --initdb add $pkg $@
else
    apk -p $os --initdb add $pkg $@
fi
#switch_root $os
that is my netboot.sh
Edited by duing
Because that's what Petitboot uses for its rootfs, and that's why it's not enabled in my build either since there's no Petitboot payload. Just pure U-Boot payload.
I’m running this system on all my devices:
Spoiler
My latest system resides on a USB-connected selfpowered storage device, so I can use it with all my devices since a USB port is basically standard nowadays. No hassle with proprietary eMMC module connectors or a potentially unavailable NVME slot. Speed-wise, it's on par with an eMMC in any case, but the GB/EUR ratio clearly speaks in favor of an NVME.
Since the necessary firmware for system startup is always located on a storage device supported by the MASKROM code (SPI flash preferred, but eMMC or microSD is on par), the operating system can be used unmodified in the same way on all devices. Just plug-in and reboot to run it instead of its usual operating system.
By the way, the screenshot was taken on my only remaining device in my collection with an Amlogic SoC. As you can see, I just updated the firmware to the state of my last build. It uses the same U-Boot binary payload as the HC4, C4 and N2,  just the closed source bloobs and the DTB differs in the firmware compose. U-Boot detects at runtime which of the four devices it's running on and acts accordingly.
