Posted (edited)
I like Guix system.
I really like it on my desktop,
so now I want to use Guix system as the OS for my Orange Pi 5 Pro as well.
The problem is, the Arm distro for Guix System is only available for Generic EFI
and I didn't have the money to buy a Orange Pi 6 Plus.
But I figure, why not install Armbian on SD card and have it boot Guix System on the SSD?
Is that possible and if so, how would I achieve that?
So far I've been able to 'dd' the guix system install ISO onto the SSD.
It seems to have an iso9660 filesystem.
Edited by Folaht Pjehrsohmehj
Posted (edited)
Maybe I am misunderstanding your question but:
Armbian is one operating system, and Guix system is another operating system, so no.
It's the equivalent of asking "can I install debian but boot NixOS from debian on another storage device".
Unless it's a virtual machine you are talking about, you might be able to run a Guix system as a virtual machine in armian, but I don't think that is what you are asking.
If you want to run Guix system, you need to boot Guix system.
If it's just the package manager Guix you are talking about, then afaik also no (if you are talking about the guile scheme), for that to work you need to run Guix system, just like you need to use NixOS to run nix package manager. But I could be incorrect.
Edited by bedna
It may be possible. But due to limited resources, forum support is limited to using Armbian as-is. Everything else goes in Off Topic.
If you're truly interested, you could attempt to take the Armbian bootloader, kernel, and device tree, and drop that into a Guix install.
But at that point, you are very much on your own.
Posted (edited)
@bedna
Yeah, that's exactly what I was asking.
I found out how to install armbian on the NVMe, which is simply to run armbian install and it does it automatically for you.
I don't see why that would be impossible if one can boot Armbian with Armbian.
Is the '/boot' section that much geared to a distro?
I thought that was just the linux kernel part.
I also get the feeling that I would probably not need Armbian at all, but u-boot installed on the SD card,
but that installing Armbian was at least a good start to see if everything was working
and what the guix system ARM iso file is an iso9660 filesystem meant for a USB device,
meaning that that I would need a pure u-boot installed on the SD card to first boot the USB device
run the guix system installer and then have u-boot boot the NVMe device.
I say 'pure u-boot' because I sometimes see these u-boot.img files floating around on the web
and just assume these might be the thing that I'm looking for.
I have no idea really.
