fxkl47BF Posted Wednesday at 09:05 PM Posted Wednesday at 09:05 PM i used nand-sata-install to move root from sd to ssd. at the end just after "Finalizing file sync ... Please wait" i got "Error while creating U-Boot loader image with mkimage" at the bottom of the screen. i rebooted and all seems to be working as planned. is this error anything to worry about? 0 Quote
tparys Posted yesterday at 01:19 AM Posted yesterday at 01:19 AM From what I've seen, that particular tool is not as well maintained as some others. If it's a major uboot failure, it won't boot. If it's working, I think that's your answer. 0 Quote
Anna1Kowalska Posted 1 hour ago Posted 1 hour ago That error with mkimage during nand-sata-install is fairly common on XU4 and usually harmless if the system boots fine afterwards. The tool is a bit outdated and often throws this warning even when U-Boot is written correctly. Since it’s working after reboot, I wouldn’t worry about it. 0 Quote
