Comprehensive Guide: Installing Armbian on the TX10 PRO (Allwinner H313)
Introduction
This technical guide documents the complete process for deploying Linux on the TX10 PRO Android TV Box (Allwinner H313).
Due to hardware variations and kernel compatibility issues common on these devices, establishing a functional Armbian environment requires specific images, DTBs, and configuration steps.
This documentation is designed to streamline the installation process and avoid common hardware compatibility problems.
Technical Specifications & Environment
The procedures in this guide were validated on a TX10 PRO with the following hardware:
Component         Specification
SoC               Allwinner H313 (sun50iw9p1)
CPU               Quad-core Cortex-A53 (ARM64)
Memory            1 GB LPDDR3 (Samsung eMCP)
Storage           8 GB eMMC
Board Revision    WFTECH_V2.0
Device Codename   titan-p1
Product           walley
Stock OS          Android (Modified Build)
Bootloader        U-Boot
Tested Kernel     Linux 6.12.64 (bookworm)
Tested working image: Armbian-unofficial_26.02.0-trunk_X96q-v1-3_bookworm_current_6.12.64_minimal.img.xz
Kernel: Linux 6.12.64 bookworm
Base OS: Debian Bookworm Server
Target: X96Q DDR3 / Allwinner H313
Although this image is labeled for the X96Q DDR3, it successfully booted on my TX10 PRO with the WFTECH_V2.0 board and Allwinner H313 SoC. Hardware revisions vary, so compatibility with other TX10 PRO units is not guaranteed.
⚠ Crucial Hardware Warning
TV box manufacturers frequently change internal components (RAM layout, Wi-Fi chipsets, and board revisions) without changing the product name.
Always verify your board revision before proceeding.
Using the wrong Device Tree Blob (DTB) can result in an unbootable system.
Advantages & Disadvantages of Running Linux
Advantages:
Cost Efficiency
Much cheaper than a Raspberry Pi or other SBC.
Enclosure Included
Comes with a case and power supply.
Low Power Consumption
Runs quietly with very low power usage, making it suitable for lightweight servers.
Disadvantages:
No Official Support
Linux support depends entirely on community-maintained images.
Thermal Throttling
Cheap passive cooling causes overheating during heavy workloads.
Weak eMMC Storage
Internal storage may wear out under frequent writes.
Slow I/O
USB ports are usually USB 2.0 only.
No SATA, NVMe, or native Gigabit Ethernet.
Driver Problems
Wi-Fi, Bluetooth, and hardware video acceleration usually require manual setup.
Prerequisite Hardwares:
MicroSD Card (8GB or larger)
MicroSD Card Reader (Cost: 0.45 USD )
HDMI Monitor (Tv)
USB Keyboard
Ethernet Adapter
Integrated Wi-Fi rarely works immediately on bookworm Linux.
A wired Ethernet connection is strongly recommended for initial setup.
Installation Process
Step 1 — Download Armbian
Official Armbian images generally do not include all hardware support for the H313.
Download a trusted community image designed for Allwinner H313/H616 boards using the 6.12.64 kernel.
USE THIS: Armbian-unofficial_26.02.0-trunk_X96q-v1-3_bookworm_current_6.12.64_minimal.img.xz
Step 2 — Flash the SD Card
⚠ Warning
Avoid using the Linux dd command if you are unfamiliar with it.
Selecting the wrong drive can permanently erase your computer.
Instead, use BalenaEtcher.
Flashing Steps:
Install and open BalenaEtcher.
Insert your MicroSD card.
Click Flash from File.
Select the downloaded .img.xz image.
Click Select Target.
Choose your MicroSD card carefully.
Click Flash!
Wait until flashing and verification reach 100%.
Safely eject the card.
Step 3 — Hardware Setup
Before powering on:
Insert the MicroSD card.
Connect HDMI.
Connect USB keyboard.
Connect USB Ethernet.
Connect power.
Step 4 — First Boot
The first boot performs:
Filesystem expansion
Initial setup
System configuration
This may take several minutes.
Expected boot sequence:
U-Boot ↓ Linux Kernel ↓ Armbian Login Prompt
Step 5 — Initial Login
Default credentials:
Username: root Password: 1234
After logging in you will be required to:
Change the root password
Create a normal user
Configure timezone
Configure locale
Step 6 — Verify Network
Built-in Wi-Fi will probably not work.
The board uses the SSV6x5x / SV6256 chipset which requires extra drivers.
Verify Ethernet:
ip a ping -c 3 1.1.1.1
Step 7 — Update the System
Enable network time:
sudo timedatectl set-ntp true
Then update:
sudo apt update sudo apt upgrade -y
Step 8 — Install to eMMC (Optional)
Once everything works from the SD card:
sudo armbian-config
Navigate to:
System ↓ Install ↓ Boot from eMMC
Follow the installer.
After completion:
Shut down
Remove the SD card
Boot from internal storage
Hardware Compatibility
Working - perfectly
HDMI Output
USB Ports
USB Ethernet
Known Issues
Wi-Fi - Not working
Requires manual compilation of the SSV6256 driver.
Graphics
No hardware acceleration.
Software rendering only.
DTB Compatibility
Boot success depends heavily on selecting the correct DTB.
Different board revisions may require different DTBs.
Best Practices
Test from SD First
Never install to eMMC before confirming that everything works.
Backup Android
Create a backup of the original Android firmware before modifying internal storage.
DTB Troubleshooting
If the device:
Boot loops
Shows a black screen
Fails to boot
Mount the SD card on another computer.
Open:
armbianEnv.txt
Try different H313/H616 DTB files until the system boots successfully.
Edited by zeyric_
