today I made an update an got the following message
The following packages will be upgraded:
  hostapd linux-image-sun8i linux-jessie-root-orangepione linux-libc-dev linux-u-boot-orangepione-default sunxi-tools
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 13,9 MB/15,0 MB of archives.
After this operation, 2.048 B of additional disk space will be used.
Get:1 http://beta.armbian.com/ jessie/jessie-utils hostapd armhf 2:2.6-4~armbian5.37.180112+1 [363 kB]
Get:2 http://beta.armbian.com/ jessie/main linux-image-sun8i armhf 5.37.180112 [12,9 MB]
Get:3 http://beta.armbian.com/ jessie/main linux-jessie-root-orangepione armhf 5.37.180112 [485 kB]
Get:4 http://beta.armbian.com/ jessie/main linux-u-boot-orangepione-default armhf 5.37.180112 [183 kB]
Get:5 http://beta.armbian.com/ jessie/jessie-utils sunxi-tools armhf 1.4.2-2~armbian5.37.180112+1 [36,2 kB]
Fetched 13,9 MB in 8s (1.690 kB/s)
(Reading database ... 32065 files and directories currently installed.)
Preparing to unpack .../hostapd_2%3a2.6-4~armbian5.37.180112+1_armhf.deb ...
Failed to execute operation: Connection timed out
Unpacking hostapd (2:2.6-4~armbian5.37.180112+1) over (2:2.6-4~armbian5.37.171231+1) ...
Preparing to unpack .../linux-image-sun8i_5.37.180112_armhf.deb ...
Unpacking linux-image-sun8i (5.37.180112) over (5.37.171231) ...
Preparing to unpack .../linux-jessie-root-orangepione_5.37.180112_armhf.deb ...
Leaving 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-orangepione'
Unpacking linux-jessie-root-orangepione (5.37.180112) over (5.37.171231) ...
Preparing to unpack .../linux-libc-dev_3.16.51-3+deb8u1_armhf.deb ...
Unpacking linux-libc-dev:armhf (3.16.51-3+deb8u1) over (3.16.51-3) ...
Preparing to unpack .../linux-u-boot-orangepione-default_5.37.180112_armhf.deb ...
Unpacking linux-u-boot-orangepione-default (5.37.180112) over (5.37.171231) ...
Preparing to unpack .../sunxi-tools_1.4.2-2~armbian5.37.180112+1_armhf.deb ...
Unpacking sunxi-tools (1.4.2-2~armbian5.37.180112+1) over (1.4.2-2~armbian5.37.171231+1) ...
Processing triggers for systemd (215-17+deb8u7) ...
dpkg: error processing package systemd (--unpack):
 subprocess installed post-installation script returned error exit status 1
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for initramfs-tools (0.120+deb8u3) ...
update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i
update-initramfs: Converting to u-boot format
Errors were encountered while processing:
 systemd
E: Sub-process /usr/bin/dpkg returned an error code (1)
what shall I do now ?
It seems to be alright now:
pi@pi-one:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up systemd (215-17+deb8u7) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
Failed to try-restart systemd-logind.service: Connection reset by peer
/var/lib/dpkg/info/systemd.postinst: 150: /var/lib/dpkg/info/systemd.postinst: cannot open /run/systemd/was-enabled: No such file
Setting up hostapd (2:2.6-4~armbian5.37.180112+1) ...
Setting up linux-image-sun8i (5.37.180112) ...
Setting up linux-jessie-root-orangepione (5.37.180112) ...
Setting up linux-libc-dev:armhf (3.16.51-3+deb8u1) ...
Setting up linux-u-boot-orangepione-default (5.37.180112) ...
Updating u-boot on /dev/mmcblk0
Setting up sunxi-tools (1.4.2-2~armbian5.37.180112+1) ...
I think it is ok now
L
