lfznnzq Posted January 20, 2018 Posted January 20, 2018 Hello everyone I have an orangepi zero with a Micro-USB (OTG) socket and an A-USB socket integrated into the board. Using the Armbian_5.35_Orangepizero_Ubuntu_xenial_next_4.13.16 system, a micro-USB cable connected to a Windows computer will have an ELMOG MAS COM device that makes it easy to manage orangepi zero. However, this Micro-USB socket is easily damaged after many times of plugging and unplugging. Can I use the A-USB socket as the USB device mode? thank you all
zador.blood.stained Posted January 20, 2018 Posted January 20, 2018 9 hours ago, lfznnzq said: Can I use the A-USB socket as the USB device mode? No, this is not possible, only the OTG port can be switched to the device mode.
