Tanix TX6 (H6): recent Armbian boot fix + cold boot MMC/eMMC hang workaround
I wanted to share what I did to get a recent Armbian build working reliably on my Tanix TX6 (Allwinner H6), in case it helps other users or developers.
My TX6 would not boot the recent Armbian image normally.
The image I was testing was based on Debian 13 Trixie with:
Linux 6.18.50-current-sunxi64
The Linux/rootfs part itself was usable, but the board would not boot correctly with the boot chain included in the recent image.
1. Getting the recent image to boot
What finally worked was creating a hybrid image.
I kept the recent Armbian Linux partition/root filesystem unchanged, but replaced the low-level boot components with those from an older TX6-compatible image.
In practice, I transplanted the older:
SPL
U-Boot
TF-A / boot chain
into the recent image.
The older working bootloader was based on U-Boot 2022.10, while the newer image contained a much newer U-Boot.
After doing this, the recent Debian 13 / kernel 6.18.50 system started booting successfully on the Tanix TX6.
So in my case the first problem did not appear to be the Debian root filesystem itself, but rather compatibility between the newer boot chain and this particular TX6.
I am currently keeping the working boot-related packages on hold so that a normal upgrade does not overwrite the configuration that boots correctly:
armbian-bsp-cli-tanix-tx6-current
armbian-firmware
linux-dtb-current-sunxi64
linux-image-current-sunxi64
linux-u-boot-tanix-tx6-current
This is only a temporary precaution while I test stability.
2. Cold boot problem
Once the hybrid image was booting, I found a second problem.
If the TX6 had been completely disconnected from power for several hours, the first boot would sometimes stop around:
Scanning for Btrfs filesystems
At first I thought Btrfs might be involved, but the root filesystem is actually EXT4.
If I waited several minutes, the system eventually produced a kernel panic with a blocked task.
The visible stack trace contained MMC-related functions including:
mmc_rescan
mmc_attach_mmc
mmc_add_card
mmc_blk_probe
mmc_blk_alloc_req
disk_scan_partitions
The strange part was that if I then removed power and immediately powered the box again, the second boot normally succeeded.
So the pattern was basically:
Long power-off
First cold boot → hangs / kernel panic
Immediate power cycle
Second boot → works normally
3. Storage identification
After a successful boot I checked the MMC devices.
On my TX6:
mmcblk0 = microSD containing Armbian
mmcblk2 = internal eMMC
The internal eMMC identifies as:
MBG4GC
and was operating as:
MMC HS200
150 MHz
8-bit bus
1.8 V signalling
The loaded Device Tree contained:
/soc/mmc@4020000  -> microSD
/soc/mmc@4021000  -> Wi-Fi / SDIO
/soc/mmc@4022000  -> internal eMMC
4. Disabling the internal eMMC
As a test, I disabled only the internal eMMC controller in Linux while leaving the microSD controller enabled.
I created this Device Tree overlay:
/dts-v1/;
/plugin/;
    fragment@0 {
        target-path = "/soc/mmc@4022000";
        __overlay__ {
            status = "disabled";
Compiled it with:
dtc -@ -I dts -O dtb \
    -o /boot/overlay-user/tx6-no-emmc.dtbo \
    tx6-no-emmc.dts
and enabled it in:
/boot/armbianEnv.txt
with:
user_overlays=tx6-no-emmc
I tested the overlay against a temporary DTB first and confirmed:
mmc@4022000 = disabled
mmc@4020000 = okay
After rebooting, Linux no longer detected the internal eMMC, while Armbian continued running normally from the microSD.
No Android/eMMC partitions were erased or modified.
5. Results so far
Since disabling the internal eMMC, the cold-boot issue has not returned.
The box has successfully booted on the first attempt after being completely disconnected from power for:
~3 hours
overnight
~2 days
and additional cold boots have also succeeded.
Before disabling the eMMC, the first boot after a long power-off could fail repeatedly.
This makes the eMMC initialization strongly suspicious in my case.
However, I cannot say whether the root cause is:
- the eMMC hardware itself
- HS200 timing
- the H6 MMC controller
- Device Tree configuration
- kernel 6.18.x MMC behaviour
- or some interaction between these
So I would not claim that the eMMC itself is faulty.
What I can say is:
disabling mmc@4022000 has made this particular TX6 consistently boot so far.
6. Bluetooth
I also had repeated Realtek Bluetooth errors such as:
hci0 command 0xfc61 tx timeout
so I blacklisted:
hci_uart
The Bluetooth errors disappeared, but the cold-boot problem still occurred before I disabled the eMMC.
Therefore I do not currently believe Bluetooth was the cause of the boot hang.
Current setup
The system is now running as a small home server with:
Armbian / Debian 13
Docker
Caddy
Portainer
Tailscale
from a microSD card.
The internal eMMC is disabled only at the Linux Device Tree level.
So far the machine has been considerably more reliable with this configuration.
If it is useful for debugging, I can provide:
- photos of the kernel panic / stack trace
- the exact DT overlay
- boot logs
- the working hybrid image layout
- details of the old and new bootloader versions
I would be interested to know whether anyone else with an H6 / Tanix TX6 can reproduce the cold-boot problem with the eMMC enabled.
Following fix should solve your boot issue: https://github.com/LibreELEC/LibreELEC.tv/blob/master/projects/Allwinner/patches/u-boot/0010-sunxi-dram-only-probe-DRAM-inside-the-addressable-range.patch
I also recently make a lot of mmc driver improvements, which may or may not help with your issue. They primarily target A523, but a lot patches affect common code. Maybe worth testing: https://github.com/LibreELEC/LibreELEC.tv/commit/5d00d15d4883f8647ee988451f413b9e3b555d02
@jernej
Thanks! I tested the DRAM patch you suggested and it appears to have solved the boot problem on my Tanix TX6.
As a first test I applied the patch to the older Armbian image I had been using:
Armbian 26.11.0-trunk.44
Debian 13 Trixie
kernel 6.18.50-current-sunxi64
That image previously would not boot with the recent U-Boot, but after rebuilding U-Boot with the DRAM probing fix it booted successfully, including a cold boot.
I then repeated the work using the newer Armbian image:
Armbian 26.11.0-trunk.59
Debian 13 Trixie
kernel 6.18.54-current-sunxi64
U-Boot 2026.07
This one also boots successfully with the patch. I am no longer transplanting the old U-Boot 2022.10 — this is a freshly rebuilt recent U-Boot with the DRAM fix applied.
From the build verification, on this H6 / 4 GB configuration the fix prevents the DRAM probing code from trying to access physical address 0x100000000, which is outside the addressable range.
For my server use I have also disabled the internal eMMC, Wi-Fi SDIO and Bluetooth UART in the Device Tree, since I do not need them. I am booting entirely from microSD and using Ethernet.
I have not applied the newer MMC driver patches yet, because with the eMMC disabled they are not currently necessary for my use case. So I cannot say whether those changes would also solve the eMMC-related cold-boot issue I was seeing previously.
I will continue doing several cold-boot tests with the 6.18.54 image, including after leaving the box completely unpowered for several hours, but so far the DRAM patch looks like the fix for the U-Boot boot failure.
Thanks again for pointing me in the right direction!
