October 15Oct 15 Good day. I've try to start WiHi HotSpot with sh script: #!/bin/bash # start_WiFi.sh - Start WiFi hotspot on Armbian # SSID: HS_Orange # Password: 12345678 # --- Configuration Parameters --- INTERFACE="wlan0" SSID="HS_Orange" PASSWORD="12345678" # --- Check for root privileges --- if [ "$EUID" -ne 0 ]; then echo "Error: Please run this script as root." exit 1 fi # --- Check if nmcli is available --- if ! command -v nmcli >/dev/null 2>&1; then echo "Error: nmcli not found. Please ensure NetworkManager is installed." exit 1 fi # --- Remove existing hotspot with the same name (if any) --- echo "Cleaning up any existing hotspot configuration..." nmcli connection delete "$SSID" 2>/dev/null # --- Create the hotspot connection --- # We create the connection with autoconnect enabled so it returns after reboot echo "Creating hotspot '$SSID'..." nmcli connection add type wifi ifname "$INTERFACE" con-name "$SSID" autoconnect yes ssid "$SSID" # --- Configure the connection as an Access Point --- echo "Configuring hotspot parameters..." # Set mode to AP, band to 2.4GHz, and enable DHCP server (shared) nmcli connection modify "$SSID" 802-11-wireless.mode ap nmcli connection modify "$SSID" 802-11-wireless.band bg nmcli connection modify "$SSID" ipv4.method shared # --- Set the WiFi password (WPA-PSK) --- echo "Setting WiFi password..." nmcli connection modify "$SSID" wifi-sec.key-mgmt wpa-psk nmcli connection modify "$SSID" wifi-sec.psk "$PASSWORD" # --- Start the hotspot --- echo "Starting hotspot..." nmcli connection up "$SSID" # --- Check status --- if nmcli connection show --active | grep -q "$SSID"; then echo "Hotspot '$SSID' started successfully." echo "Password: $PASSWORD" echo "Gateway IP: $(nmcli -g IP4.ADDRESS connection show "$SSID" | cut -d/ -f1)" else echo "Error: Failed to start hotspot. Check logs with: journalctl -u NetworkManager" exit 1 fi Which ended with error: Setting WiFi password... Starting hotspot... Error: Connection activation failed: 802.1X supplicant took too long to authenticate Hint: use 'journalctl -xe NM_CONNECTION=3e863319-1060-4bf8-bec3-1f1b3d38a921 + NM_DEVICE=wlan0' to get more details. Error: Failed to start hotspot. Check logs with: journalctl -u NetworkManager journalctl is: Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4361] device (wlan0): Activation: starting connection 'HS_Orange' (2b59208d-2aaa-4c56-a637-f9173725ead4) Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4369] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full') Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4397] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full') Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4409] device (wlan0): Activation: (wifi) access point 'HS_Orange' has security, but secrets are required. Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4410] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full') Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4453] device (wlan0): state change: need-auth -> prepare (reason 'none', managed-type: 'full') Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4484] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full') Oct 15 12:38:27 orangepi3-lts NetworkManager[605]: <info> [1792067907.4495] device (wlan0): Activation: (wifi) connection 'HS_Orange' has security, and secrets exist. No new secrets> Oct 15 12:38:52 orangepi3-lts NetworkManager[605]: <warn> [1792067932.8088] device (wlan0): Activation: (wifi) Hotspot network creation took too long, failing activation Oct 15 12:38:52 orangepi3-lts NetworkManager[605]: <info> [1792067932.8090] device (wlan0): state change: config -> failed (reason 'supplicant-timeout', managed-type: 'full') Oct 15 12:38:52 orangepi3-lts NetworkManager[605]: <warn> [1792067932.8133] device (wlan0): Activation: failed for connection 'HS_Orange' Oct 15 12:38:52 orangepi3-lts NetworkManager[605]: <info> [1792067932.8151] device (wlan0): state change: failed -> disconnected (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8556] device (wlan0): Activation: starting connection 'HS_Orange' (2b59208d-2aaa-4c56-a637-f9173725ead4) Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8564] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8626] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8647] device (wlan0): Activation: (wifi) access point 'HS_Orange' has security, but secrets are required. Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8649] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8732] device (wlan0): state change: need-auth -> prepare (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8787] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full') Oct 15 12:39:00 orangepi3-lts NetworkManager[605]: <info> [1792067940.8808] device (wlan0): Activation: (wifi) connection 'HS_Orange' has security, and secret and ip link is: control@orangepi3-lts:~/Scripts$ ip link 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether 02:07:f3:49:3a:e3 brd ff:ff:ff:ff:ff:ff altname enx0207f3493ae3 3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DORMANT group default qlen 1000 link/ether 90:86:36:28:65:52 brd ff:ff:ff:ff:ff:ff altname wlx908636286552 control@orangepi3-lts:~/Scripts$ Any advice much appreciated.
