October 15Oct 15 Hello, I am trying to use ZFS on my Rock5B+, I use Armbian Ubuntu 26.04 Minimal current 6.18.45 and did a fresh install just to be sure and installed the Linux headers in armbian-config. The option to enable ZFS in armbian-config says it failed to do so and when I try manually I get this dependency error: apt install zfs-dkms zfsutils-linux -y Solving dependencies... Error! Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: Unsatisfied dependencies: zfs-dkms : Depends: dkms (>= 3.0.11) but it is not going to be installed Depends: file but it is not going to be installed zfsutils-linux : Depends: libnvpair3linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed Depends: libuutil3linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed Depends: libzfs7linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed Depends: libzpool7linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed Depends: gawk but it is not going to be installed Breaks: zfs-dkms (> 2.4.4-1arter97~ubuntu26.04.1...) Error: Unable to satisfy dependencies. Reached two conflicting assignments: 1. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 is selected for install 2. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 is not selected for install because: 1. zfs-dkms:arm64=2.4.4-2arter97~ubuntu26.04.1 is selected for install 2. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 Breaks zfs-dkms (> 2.4.4-1arter97~ubuntu26.04.1...) If I just do "apt install zfsutils-linux", I get this: apt install zfsutils-linux Installing: zfsutils-linux Installing dependencies: gawk libnvpair3linux libuutil3linux libzfs7linux libzpool7linux Suggested packages: gawk-doc nfs-kernel-server samba-common-bin zfs-initramfs | zfs-dracut Recommended packages: zfs-zed Summary: Upgrading: 0, Installing: 6, Removing: 0, Not Upgrading: 0 Download size: 2,886 kB Space needed: 10.1 MB / 238 GB available Continue? [Y/n] Get:1 http://ports.ubuntu.com resolute-security/main arm64 gawk arm64 1:5.3.2-1ubuntu1.1 [515 kB] Get:2 http://apt.armbian.com resolute/resolute-utils arm64 libnvpair3linux arm64 2.4.4-1arter97~ubuntu26.04.1 [59.5 kB] Get:3 http://apt.armbian.com resolute/resolute-utils arm64 libuutil3linux arm64 2.4.4-1arter97~ubuntu26.04.1 [51.3 kB] Get:4 http://apt.armbian.com resolute/resolute-utils arm64 libzfs7linux arm64 2.4.4-1arter97~ubuntu26.04.1 [246 kB] Get:5 http://apt.armbian.com resolute/resolute-utils arm64 libzpool7linux arm64 2.4.4-1arter97~ubuntu26.04.1 [1,394 kB] Get:6 http://apt.armbian.com resolute/resolute-utils arm64 zfsutils-linux arm64 2.4.4-1arter97~ubuntu26.04.1 [620 kB] Fetched 2,886 kB in 2s (1,438 kB/s) Selecting previously unselected package gawk. (Reading database… 64247 files and directories currently installed.) Preparing to unpack …/0-gawk_1%3a5.3.2-1ubuntu1.1_arm64.deb… Unpacking gawk (1:5.3.2-1ubuntu1.1)… Selecting previously unselected package libnvpair3linux:arm64. Preparing to unpack …/1-libnvpair3linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb… Unpacking libnvpair3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Selecting previously unselected package libuutil3linux:arm64. Preparing to unpack …/2-libuutil3linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb… Unpacking libuutil3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Selecting previously unselected package libzfs7linux:arm64. Preparing to unpack …/3-libzfs7linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb… Unpacking libzfs7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Selecting previously unselected package libzpool7linux:arm64. Preparing to unpack …/4-libzpool7linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb… Unpacking libzpool7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Selecting previously unselected package zfsutils-linux. Preparing to unpack …/5-zfsutils-linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb… Unpacking zfsutils-linux (2.4.4-1arter97~ubuntu26.04.1)… Setting up libnvpair3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Setting up gawk (1:5.3.2-1ubuntu1.1)… Setting up libuutil3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Setting up libzpool7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… Setting up libzfs7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)… No diversion «diversion of /lib/aarch64-linux-gnu/libzfs_core.so.3 to /lib/aarch64-linux-gnu/libzfs_core.so.3.usr-is-merged by libzfs6linux», none removed. No diversion «diversion of /lib/aarch64-linux-gnu/libzfs_core.so.3.0.0 to /lib/aarch64-linux-gnu/libzfs_core.so.3.0.0.usr-is-merged by libzfs6linux», none removed. Setting up zfsutils-linux (2.4.4-1arter97~ubuntu26.04.1)… modprobe: FATAL: Module zfs not found in directory /lib/modules/6.18.44-current-rockchip64 Created symlink '/etc/systemd/system/zfs-import.target.wants/zfs-import-cache.service' → '/usr/lib/systemd/system/zfs-import-cache.service'. Created symlink '/etc/systemd/system/zfs.target.wants/zfs-import.target' → '/usr/lib/systemd/system/zfs-import.target'. Created symlink '/etc/systemd/system/zfs-mount.service.wants/zfs-load-module.service' → '/usr/lib/systemd/system/zfs-load-module.service'. Created symlink '/etc/systemd/system/zfs.target.wants/zfs-load-module.service' → '/usr/lib/systemd/system/zfs-load-module.service'. Created symlink '/etc/systemd/system/zfs.target.wants/zfs-mount.service' → '/usr/lib/systemd/system/zfs-mount.service'. Created symlink '/etc/systemd/system/zfs.target.wants/zfs-share.service' → '/usr/lib/systemd/system/zfs-share.service'. Created symlink '/etc/systemd/system/zfs-volumes.target.wants/zfs-volume-wait.service' → '/usr/lib/systemd/system/zfs-volume-wait.service'. Created symlink '/etc/systemd/system/zfs.target.wants/zfs-volumes.target' → '/usr/lib/systemd/system/zfs-volumes.target'. Created symlink '/etc/systemd/system/multi-user.target.wants/zfs.target' → '/usr/lib/systemd/system/zfs.target'. zfs-import-scan.service is a disabled or a static unit, not starting it. Processing triggers for man-db (2.13.1-1build1)… Processing triggers for libc-bin (2.43-2ubuntu2.4)… I get "modprobe: FATAL: Module zfs not found in directory /lib/modules/6.18.44-current-rockchip64" and after the install I also tried to directly compile ZFS from the GitHub but I had no more success... I tried all the things I could think of, so if someone sees what I'm doing wrong or had the same issue, I'm open to every suggestions.
November 9Nov 9 I had a similar problem where modprobe was reporting modprobe: FATAL: Module zfs not found in directory ... My setup is slightly different because I run the edge kernel and always compile zfs from source. (For completeness sake, I don't use any configuration options, just ./configure && make && sudo make install)After modprobe failed, I checked the dmesg log where I found this:spl: version magic '7.3.1 SMP preempt mod_unload aarch64' should be '7.3.1-edge-rockchip64 SMP preempt mod_unload aarch64'Fascinating. The output from ./configure showed that zfs was computing the wrong kernel version and the module was built with the wrong version magic as a result. It's missing the tag -edge-rockchip64 at the end.checking kernel source version... 7.3.1I tracked it down to this file$ cat /usr/src/linux-headers-7.3.1-edge-rockchip64/include/generated/utsrelease.h #define UTS_RELEASE "7.3.1"And, yes, editing this file to change the value of UTS_RELEASE to "7.3.1-edge-rockchip64" fixed the problem. This is a gross hack though, and I don't know if it will solve your problem.FWIW, I have just built the 7.3.3 edge kernel and it seems to not have this issue:$ cat /usr/src/linux-headers-7.3.3-edge-rockchip64/include/generated/utsrelease.h #define UTS_RELEASE "7.3.3-edge-rockchip64"
