Hello, I am trying to use ZFS on my Rock5B+, I use Armbian Ubuntu 26.04 Minimal current 6.18.45 and did a fresh install just to be sure and installed the Linux headers in armbian-config.
The option to enable ZFS in armbian-config says it failed to do so and when I try manually I get this dependency error:
apt install zfs-dkms zfsutils-linux -y
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
zfs-dkms : Depends: dkms (>= 3.0.11) but it is not going to be installed
Depends: file but it is not going to be installed
zfsutils-linux : Depends: libnvpair3linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed
Depends: libuutil3linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed
Depends: libzfs7linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed
Depends: libzpool7linux (= 2.4.4-1arter97~ubuntu26.04.1) but it is not going to be installed
Depends: gawk but it is not going to be installed
Breaks: zfs-dkms (> 2.4.4-1arter97~ubuntu26.04.1...)
Error: Unable to satisfy dependencies. Reached two conflicting assignments:
1. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 is selected for install
2. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 is not selected for install because:
1. zfs-dkms:arm64=2.4.4-2arter97~ubuntu26.04.1 is selected for install
2. zfsutils-linux:arm64=2.4.4-1arter97~ubuntu26.04.1 Breaks zfs-dkms (> 2.4.4-1arter97~ubuntu26.04.1...)
If I just do "apt install zfsutils-linux", I get this:
Installing:
zfsutils-linux
Installing dependencies:
gawk libnvpair3linux libuutil3linux libzfs7linux libzpool7linux
Suggested packages:
gawk-doc nfs-kernel-server samba-common-bin zfs-initramfs | zfs-dracut
Recommended packages:
zfs-zed
Summary:
Upgrading: 0, Installing: 6, Removing: 0, Not Upgrading: 0
Download size: 2,886 kB
Space needed: 10.1 MB / 238 GB available
Continue? [Y/n]
Get:1 http://ports.ubuntu.com resolute-security/main arm64 gawk arm64 1:5.3.2-1ubuntu1.1 [515 kB]
Get:2 http://apt.armbian.com resolute/resolute-utils arm64 libnvpair3linux arm64 2.4.4-1arter97~ubuntu26.04.1 [59.5 kB]
Get:3 http://apt.armbian.com resolute/resolute-utils arm64 libuutil3linux arm64 2.4.4-1arter97~ubuntu26.04.1 [51.3 kB]
Get:4 http://apt.armbian.com resolute/resolute-utils arm64 libzfs7linux arm64 2.4.4-1arter97~ubuntu26.04.1 [246 kB]
Get:5 http://apt.armbian.com resolute/resolute-utils arm64 libzpool7linux arm64 2.4.4-1arter97~ubuntu26.04.1 [1,394 kB]
Get:6 http://apt.armbian.com resolute/resolute-utils arm64 zfsutils-linux arm64 2.4.4-1arter97~ubuntu26.04.1 [620 kB]
Fetched 2,886 kB in 2s (1,438 kB/s)
Selecting previously unselected package gawk.
(Reading database… 64247 files and directories currently installed.)
Preparing to unpack …/0-gawk_1%3a5.3.2-1ubuntu1.1_arm64.deb…
Unpacking gawk (1:5.3.2-1ubuntu1.1)…
Selecting previously unselected package libnvpair3linux:arm64.
Preparing to unpack …/1-libnvpair3linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb…
Unpacking libnvpair3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Selecting previously unselected package libuutil3linux:arm64.
Preparing to unpack …/2-libuutil3linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb…
Unpacking libuutil3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Selecting previously unselected package libzfs7linux:arm64.
Preparing to unpack …/3-libzfs7linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb…
Unpacking libzfs7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Selecting previously unselected package libzpool7linux:arm64.
Preparing to unpack …/4-libzpool7linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb…
Unpacking libzpool7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Selecting previously unselected package zfsutils-linux.
Preparing to unpack …/5-zfsutils-linux_2.4.4-1arter97~ubuntu26.04.1_arm64.deb…
Unpacking zfsutils-linux (2.4.4-1arter97~ubuntu26.04.1)…
Setting up libnvpair3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Setting up gawk (1:5.3.2-1ubuntu1.1)…
Setting up libuutil3linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Setting up libzpool7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
Setting up libzfs7linux:arm64 (2.4.4-1arter97~ubuntu26.04.1)…
No diversion «diversion of /lib/aarch64-linux-gnu/libzfs_core.so.3 to /lib/aarch64-linux-gnu/libzfs_core.so.3.usr-is-merged by libzfs6linux», none removed.
No diversion «diversion of /lib/aarch64-linux-gnu/libzfs_core.so.3.0.0 to /lib/aarch64-linux-gnu/libzfs_core.so.3.0.0.usr-is-merged by libzfs6linux», none removed.
Setting up zfsutils-linux (2.4.4-1arter97~ubuntu26.04.1)…
modprobe: FATAL: Module zfs not found in directory /lib/modules/6.18.44-current-rockchip64
Created symlink '/etc/systemd/system/zfs-import.target.wants/zfs-import-cache.service' → '/usr/lib/systemd/system/zfs-import-cache.service'.
Created symlink '/etc/systemd/system/zfs.target.wants/zfs-import.target' → '/usr/lib/systemd/system/zfs-import.target'.
Created symlink '/etc/systemd/system/zfs-mount.service.wants/zfs-load-module.service' → '/usr/lib/systemd/system/zfs-load-module.service'.
Created symlink '/etc/systemd/system/zfs.target.wants/zfs-load-module.service' → '/usr/lib/systemd/system/zfs-load-module.service'.
Created symlink '/etc/systemd/system/zfs.target.wants/zfs-mount.service' → '/usr/lib/systemd/system/zfs-mount.service'.
Created symlink '/etc/systemd/system/zfs.target.wants/zfs-share.service' → '/usr/lib/systemd/system/zfs-share.service'.
Created symlink '/etc/systemd/system/zfs-volumes.target.wants/zfs-volume-wait.service' → '/usr/lib/systemd/system/zfs-volume-wait.service'.
Created symlink '/etc/systemd/system/zfs.target.wants/zfs-volumes.target' → '/usr/lib/systemd/system/zfs-volumes.target'.
Created symlink '/etc/systemd/system/multi-user.target.wants/zfs.target' → '/usr/lib/systemd/system/zfs.target'.
zfs-import-scan.service is a disabled or a static unit, not starting it.
Processing triggers for man-db (2.13.1-1build1)…
Processing triggers for libc-bin (2.43-2ubuntu2.4)…
I get "modprobe: FATAL: Module zfs not found in directory /lib/modules/6.18.44-current-rockchip64" and after the install
I also tried to directly compile ZFS from the GitHub but I had no more success...
I tried all the things I could think of, so if someone sees what I'm doing wrong or had the same issue, I'm open to every suggestions.
