Arslan Munir Posted January 25, 2018 Posted January 25, 2018 Hello, I've been trying to interface Kedei hdmi 3.5 inch hdmi lcd (480x320) with orangepi one. So far i"ve been unable to display anything on lcd using Armbian mainline kernal image. But with legacy kernal using h3disp command i was able to change the resolution but the lcd than gave message " Not Supported". Can someone please help me how to do this?
FredrikA Posted January 26, 2018 Posted January 26, 2018 This was tricky enough on raspberry pi, an unsupported screen on a supported platform, where I finally got it working. I haven't even tried to get it working on this half-supported platform. What I had to do on raspberry was add one line to /boot/config.txt dtoverlay=ads7846,cs=0,penirq=25,penirq_pull=2,speed=10000,keep_vref_on=0,swap_xy=1,pmax=255,xohms=150,xmin=5837,xmax=35819,ymin=59198,ymax=27978 please note that the [xy][min|max] are calibrated values for my screen. And I needed this in a new file in /usr/share/X11/x.org.conf called 98-calibration.conf Section "InputClass" Identifier "calibration" MatchProduct "ADS7846 Touchscreen" Option "MinX" "5837" Option "MaxX" "35819" Option "MinY" "27978" Option "MaxY" "59198" Option "SwapXY" "1" Option "SwapAxes" "1" Option "InvertX" "0" Option "InvertY" "1" Option "TransformationMatrix" "1 0 0 0 -1 1 0 0 1" EndSection I think I added these max and min x and y values in one place more than I needed, but when it finally worked,..... The dtoverlay ads7846 is not compiled for armbian as far as I know. I don't even have the source code. good luck.
Arslan Munir Posted February 7, 2018 Author Posted February 7, 2018 On 26/01/2018 at 8:53 PM, FredrikA said: This was tricky enough on raspberry pi, an unsupported screen on a supported platform, where I finally got it working. I haven't even tried to get it working on this half-supported platform. What I had to do on raspberry was add one line to /boot/config.txt dtoverlay=ads7846,cs=0,penirq=25,penirq_pull=2,speed=10000,keep_vref_on=0,swap_xy=1,pmax=255,xohms=150,xmin=5837,xmax=35819,ymin=59198,ymax=27978 please note that the [xy][min|max] are calibrated values for my screen. And I needed this in a new file in /usr/share/X11/x.org.conf called 98-calibration.conf Section "InputClass" Identifier "calibration" MatchProduct "ADS7846 Touchscreen" Option "MinX" "5837" Option "MaxX" "35819" Option "MinY" "27978" Option "MaxY" "59198" Option "SwapXY" "1" Option "SwapAxes" "1" Option "InvertX" "0" Option "InvertY" "1" Option "TransformationMatrix" "1 0 0 0 -1 1 0 0 1" EndSection I think I added these max and min x and y values in one place more than I needed, but when it finally worked,..... The dtoverlay ads7846 is not compiled for armbian as far as I know. I don't even have the source code. good luck. Hmm. Ok. Thanks for the reply
