5 hours ago5 hr I need a USB gadget that enumerates at SuperSpeed, not High-Speed, and I can't find a straight answer for RK3399.On a ROCK Pi 4 with mainline, setting dr_mode = "peripheral" on usbdrd_dwc3_0 gives a working UDC and gadgets bind fine. What I can't find is what speed it actually trains at.For RK3588 it's reported that the Type-C port does USB 3.x in host mode but is capped to USB 2.0 in device mode. Does the same cap apply to RK3399, or does its dwc3 really do SuperSpeed peripheral?If anyone has an RK3399 board running in peripheral mode, two outputs would settle it. On the board:cat /sys/class/udc/*/maximum_speed /sys/class/udc/*/current_speedAnd on the PC it is plugged into:lsusb -t | grep 5000MAsking before I buy one. Thanks. Edited 5 hours ago5 hr by well0nez
5 hours ago5 hr On Armbian/mainline, RK3399 should support SuperSpeed peripheral mode through DWC3. Try explicitly setting both:dtsdr_mode = "peripheral"; maximum-speed = "super-speed"; There are reports of current_speed reaching super-speed on the ROCK Pi 4C+. However, confirmation on the exact ROCK Pi 4 model and Armbian kernel version would be appreciated.
