10 hours ago10 hr The FriendlyELEC YX35 display on my NanoPi M6 V1 shows the desktop over DSI1, but touch is unresponsive with the Armbian vendor kernel.Tested setup- FriendlyELEC NanoPi M6 V1 (RK3588S), YX35 connected to DSI1, booting from microSD.- Armbian 26.8.10 Ubuntu Resolute GNOME, kernel 6.1.172-vendor-rk35xx, overlay nanopi-m6-display-dsi1-yx35.- The report comes from a customized installation derived from that Armbian image. It retained the stock kernel and touch device-tree node for the failing test. A fresh, unmodified image was not tested separately.How to reproduceEnable the YX35 DSI1 overlay, boot into the desktop, tap the screen, and check /proc/bus/input/devices and the kernel log. Expected behavior is normal touch input. On the tested board the display works, but no touchscreen input device is registered.The device-tree node /i2c@fead0000/gt1x@14 advertises the compatible string goodix,gt1x. The vendor GT1X driver tries to probe I²C client 5-0014 and the relevant log is:<<GTP-ERR>>[gt1x_init:2380] Get chip type failed!<<GTP-ERR>>[gt1x_ts_probe:573] GTP init failed!!!Goodix-TS-GT1X: probe of 5-0014 failed with error -1Verified on hardwareAn out-of-tree Goodix driver built from Linux 6.1.172 against the matching Armbian headers successfully probed the same device. The test driver used the name M6-GT911 because the kernel already has a built-in driver registered as Goodix-TS. The replacement reported ID 911, version: 1060, registered a touchscreen, and produced touch contact and coordinate events in evtest. Desktop taps and their positions were verified on the board. This was a live test.The Armbian GT1X hardware type check (https://github.com/armbian/linux-rockchip/blob/rk-6.1-rkr7.2/drivers/input/touchscreen/gt1x/gt1x_generic.c#L841-L875) checks two hardware signatures. The FriendlyELEC 6.1 branch (https://github.com/friendlyarm/kernel-rockchip/blob/nanopi6-v6.1.y/drivers/input/touchscreen/gt1x/gt1x_generic.c#L844-L878) also checks a GT911 signature. The failing probe did not capture the raw hardware-info bytes, so the signature difference is a lead for a fix.Could the vendor kernel's GT911 support for this panel be checked against FriendlyELEC's GT1X changes?
