Édney Helene Posted February 12, 2018 Posted February 12, 2018 hello there, i bought this box wich is pre rooted! i burn the image to usb, and also copy dtb.usb image to boot directory but i dont seem to be able to get into linux! I go into update and select the linux script and it reboots, but it shows an android figure saying " error" and then i have to restart back to android.. im trying to boot armibian or ubuntu or similars... So anyone got lucky installing linux into this box? i really need it thanks in advance..even libreelec would make me happy, i wanna test other Os into this! followed all tutorials on internet but no lucky =(((
rafaelSorel Posted February 26, 2018 Posted February 26, 2018 you need to find a dtb file that could be used with that particular box, the S905W are quite different , so with some luck, one of the dtb files for the s905x or s905 will work. Otherwise you need to extract the dtb file in use on android and adapt it.
Édney Helene Posted March 6, 2018 Author Posted March 6, 2018 On 2/26/2018 at 1:02 PM, rafaelSorel said: you need to find a dtb file that could be used with that particular box, the S905W are quite different , so with some luck, one of the dtb files for the s905x or s905 will work. Otherwise you need to extract the dtb file in use on android and adapt it. No lucky at all!
