hi All, I'm new on this forum, very great work all OMV project!
I have a banana router, also called LamoboR1, an ARM powered very powerfull router, I can install Wheezy or Jessy (I think Jessie would be better) an other this install OMV on wheezy I havent 'got any problem I instal OMV Stoneburner and after I upgrade via omv-release-upgrade to Erasmus ( little question does Ownlcoud run on Erasmus, can't find it in omv extras repo ? crying.png ).
When I try to install OMV from Jessie I get this error
    The following packages have unmet dependencies:
    openmediavault : Depends: php5-pam but it is not going to be installed
    Depends: proftpd-mod-vroot but it is not going to be installed
    Depends: php5-proctitle but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
and I'm unable to install them manually gets error like
root@BananaLesOlivades:~# apt-get install php5-pam
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
php5-pam : Depends: phpapi-20100525+lfs but it is not installable
does anyone have an idea? is a problem of my installed Jessie, or Erasmus is not yet compatible ?
i'm using os from
thanks a lot remy
I have no experience with openmediavault, but I think it says where you have to search for a solution:
Did you already dive into this topic?
