I have a 320x240 ili9341 based lcd.
Based on the instructions on this forum I hooked it up to my orangepi pc (latest desktop) , loaded the fb kernel driver and run some tests.
MPlayer (sudo SDL_VIDEODRIVER=fbcon SDL_FBDEV=/dev/fb8 mplayer -vo sdl -framedrop test.mpg) runs fine. The display shows the video without any problems.
Also some python scripts work fine (clock etc..)
But anything else fails....
con2fbmap 1 8 does nothing
Using FRAMBUFFER=/dev/fb8 startx (or any other program) just starts everything in the main display (hdmi).
I need to be able to run any program I want on the spi lcd.
Am I missing something?
Ok,
Just in case anyone else is having the same problem: check your nodm config.
You will get very strange behavior if nodm is not properly configured.
