Build configuration is:
     * use_rpi = 0
     * use_mali = 0
     * use_egl = 0
     * use_opengl_es2 = 0
     * use_opengl_mock = 0
     * use_sdl2 = 0
     * use_ios = 0
     * use_mesagl = 0
     * use_x11 = 0
     * use_gstreamer = 0
     * use_avfoundation = 0
     * use_osx_frameworks = 0
     * debug_gl = 0
     * debug = False
How can I change this if anyone know? Good thing to have mali online :)
  On 3/21/2018 at 10:24 PM, Vladimir Petrovic said:
Anyone done kivy pip on Zero? Have problem with pip install kivy. Stuck on :
/usr/bin/ld: cannot find -lGL
    collect2: error: ld returned 1 exit status
Expand
library was out of path.
ln -s /usr/lib/arm-linux-gnueabihf/mesa/libGL.so.1 /lib/libGL.so
did job...
cythoning /tmp/pip-build-EOjUJ7/kivy/kivy/graphics/svg.pyx to /tmp/pip-build-EOjUJ7/kivy/kivy/graphics/svg.c
     Error compiling Cython file:
                     end = time()
                     Logger.debug("Svg: Loaded {} in {:.2f}s".format(filename, end - start))
                 finally:
                     fd.close()
         cdef void reload(self) except *:
     kivy/graphics/svg.pyx:469:9: Signature not compatible with previous declaration
             cpdef flag_update(self, int do_parent=?, list _instrs=?)
         ELSE:
             cpdef flag_update(self, int do_parent=?)
         cdef void flag_update_done(self)
         cdef void set_parent(self, Instruction parent)
     kivy/graphics/instructions.pxd:36:20: Previous declaration is here
Any idea?
