Roman B Posted March 28, 2018 Posted March 28, 2018 Hi there, I have a Banana Pi M1+ and connected to it Silicon Power SSD 60 Gb. I've faced with the following error: Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00(see screenshots). Startup: https://drive.google.com/open?id=1s_1mkJWXTC02TnSyVlX8oZZQDaJpgXYu Kernel panic message: https://drive.google.com/open?id=1oDgmnrOspkYy5DY5bobFLTJSE3RJOVE6 I downloaded and wrote Armiban to the SD card from this link: https://dl.armbian.com/bananapi/Debian_stretch_next.7z, It started well. Then I performed apt update && apt upgrade -y and reboot the system. After that I've used 'nand-sata-install' to move system to SATA SSD and got that error. Previouslly I did the same steps with usual Banana Pi M1 (not plus version) and it works well, but with the M1 plus version I got that error. Thanks, Roman.
tkaiser Posted March 28, 2018 Posted March 28, 2018 Can you do the following test please? Reimage SD card with Debian_stretch_next.7z, boot, apply all updates, shutdown, connect the SSD, then turn the board back on again. Then please provide output from armbianmonitor -u No further steps needed at this moment.
Roman B Posted March 28, 2018 Author Posted March 28, 2018 Hello @tkaiser, Please see below the results of specified command: armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/13H5 Please post the URL in the forum where you've been asked for.
tkaiser Posted March 28, 2018 Posted March 28, 2018 10 minutes ago, Roman B said: Please see below the results of specified command Thank you. I was looking for underpowering but that's totally fine (5.19V with connected SSD): ### Boot system health: Time CPU load %cpu %sys %usr %nice %io %irq CPU PMIC DC-IN C.St. 09:54:20: 960MHz 1.05 76% 40% 32% 0% 3% 0% 37.0°C 29.4°C 5.19V 0/6 09:54:21: 960MHz 1.20 73% 31% 36% 2% 3% 0% 37.1°C 29.2°C 5.26V 0/6 09:54:22: 960MHz 1.20 35% 28% 3% 2% 1% 0% 36.3°C 28.7°C 5.23V 0/6 09:54:23: 960MHz 1.20 24% 16% 0% 2% 5% 0% 35.6°C 28.3°C 5.25V 0/6 09:54:25: 960MHz 1.20 15% 9% 0% 1% 4% 0% 35.5°C 28.5°C 5.22V 0/6 Please note that you're now running with 4.14.14 (as expected) while you were on 4.13 before which is a bit weird given that you installed all updates.
Roman B Posted March 28, 2018 Author Posted March 28, 2018 @tkaiser, could you please clarify your note about kernel versions, I didn't quite catch it.
tkaiser Posted March 28, 2018 Posted March 28, 2018 On your screenshot the kernel panic happens with a 4.13 kernel while now after you applied all updates you're on 4.14. So my assumption is that something went wrong before (you said 'I performed apt update && apt upgrade -y and reboot the system' -- but then you should've also been running with 4.14)
Roman B Posted March 28, 2018 Author Posted March 28, 2018 @tkaiser, thank you for clarification. It is because I provided screen captures for different attempts. I tried to use older version of armbian, but every time I got the same version. Now I've plugged 3A power supply and upgrade OS to the 4.14.18 version of kernel. Take a look at mon logs: http://ix.io/13Ih.
Roman B Posted March 28, 2018 Author Posted March 28, 2018 Changing power supply didn't help. Any ideas how to figure out the root cause of that issue or how to resolve it?
tkaiser Posted March 28, 2018 Posted March 28, 2018 Can you try to capture the lines prior to the kernel panic. Without serial console it can become hard to diagnose this since without looking through a detailed log this becomes a job for mind readers
Roman B Posted March 28, 2018 Author Posted March 28, 2018 I've posted photo for it in my first comment on this issue. Let me duplicate it in attachment to this comment: Spoiler And there are no other lines, just kernel panic after this screen. Thanks, Roman.
tkaiser Posted March 29, 2018 Posted March 29, 2018 Please see how to increase boot verbosity: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-toogle-verbose-boot Do you have a serial console? That would be really helpful since it allows to record the boot process with increased boot verbosity. Then if the issue only occurs after you executed nand-sata-install can you take the SD card, access the rootfs and pastebin /var/log/armhwinfo.log and /var/log/nand-sata-install.log?
Roman B Posted March 29, 2018 Author Posted March 29, 2018 Hello @tkaiser, thank you for provided tips. I'm still collecting this data, which you have requested and I will add it later. Also it looks like I managed to find out one of the reason of the issue: It is new version of Silicon Power SSD drive (SP60). The same issue I've got if try to use Banana Pi M1 with that SSDs, so issue appears not only with M1 + and also with usual M1(I have several such SSDs, so it is not a problem of a particular one). If I transfer system to the old version of SSD, everything works. Thanks, Roman.
Roman B Posted March 30, 2018 Author Posted March 30, 2018 Hi @tkaiser, I wrote the latest version on the new SD card, then performed apt-update && apt upgrade. Then I ran nand-sata-intall. Set logs verbosity to 7 and collect logs from SSD and SD card. Please take a look at attached logs.. logs fom SSD.7z kern.log nand-sata-install.log armhwinfo.log
Roman B Posted March 30, 2018 Author Posted March 30, 2018 I see the following lines in the kern.log: Mar 29 18:01:22 localhost kernel: [ 152.729764] EXT4-fs (sda1): Unrecognized mount option "compress-force=zlib" or missing value Mar 29 18:01:22 localhost kernel: [ 152.810043] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) Looks like it tried to use 'compress-force=zlib' for EXT4 fs, is it ok?
tkaiser Posted March 30, 2018 Posted March 30, 2018 3 hours ago, Roman B said: Looks like it tried to use 'compress-force=zlib' for EXT4 fs, is it ok? This is harmless. But I found a serious issue in nand-sata-install.log: Checking again for open files: apt.syste 1377 root 11w REG 179,1 0 35214 /var/lib/apt/daily_lock unattende 1411 root 4uW REG 179,1 0 35242 /var/lib/dpkg/lock http 2483 _apt 4u REG 179,1 4370166 37513 /var/cache/apt/archives/partial/g++-6_6.3.0-18+deb9u1_armhf.deb That means unattended-upgrades was running while the installation has been cloned with rsync which will result in a corrupted installation for sure. This is something that needs a fix in nand-sata-install anyway. Cloning a running system is always a problem but with a running install orgy in the background it must fail.
Roman B Posted March 30, 2018 Author Posted March 30, 2018 I've tried it again with disabled unattended-update and got the same results. Spoiler Fri Mar 30 14:24:34 UTC 2018: Start nand-sata-install. Old UUID: UUID=62fc7248-9a57-4024-90d9-b4767bd2c697 SD UUID: UUID=62fc7248-9a57-4024-90d9-b4767bd2c697 SATA UUID: UUID=efedf86c-3710-4406-86e1-5c48a9e12aef eMMC UUID: Boot: $1 Root: $2 /dev/sda1 ext4 Usage: 1123 Dest: 53155 /etc/fstab: UUID=62fc7248-9a57-4024-90d9-b4767bd2c697 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 /var/swap none swap sw 0 0 /etc/mtab: /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 /dev/sda1 /mnt/nand-sata-install.iK7mhx/rootfs ext4 rw,relatime,data=ordered 0 0 Files currently open for writing: dhclient 726 root 4w REG 179,1 1026 37490 /var/lib/dhcp/dhclient.eth0.leases Trying to stop running services to minimize open files: Stopping cron.service Checking again for open files: Copying 37336 files to /dev/sda1. Finishing transfer to USB/SATA, boot from SD/eMMC Checking again for open files: Fri Mar 30 14:33:07 UTC 2018: Finished So it is definitely not related to the updates. Only one thing which make it works well is to change SSD drive, so my suggestion is only one: some errors appears because of unsupported SSD drive. But hot to solve it?
