Banana Pi M1+ kernel panic after transfer OS to SATA SSD.
Roman B
Hi there,
I have a Banana Pi M1+ and connected to it Silicon Power SSD 60 Gb.
I've faced with the following error: Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00(see screenshots).
I downloaded and wrote Armiban to the SD card from this link: https://dl.armbian.com/bananapi/Debian_stretch_next.7z,
It started well.
Then I performed apt update && apt upgrade -y and reboot the system.
After that I've used 'nand-sata-install' to move system to SATA SSD and got that error.
Previouslly I did the same steps with usual Banana Pi M1 (not plus version) and it works well, but with the M1 plus version I got that error.
Thanks, Roman.
Can you do the following test please? Reimage SD card with Debian_stretch_next.7z, boot, apply all updates, shutdown, connect the SSD, then turn the board back on again. Then please provide output from
armbianmonitor -u
No further steps needed at this moment.
10 minutes ago, Roman B said:
Please see below the results of specified command
Thank you. I was looking for underpowering but that's totally fine (5.19V with connected SSD):
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC   DC-IN  C.St.
09:54:20:  960MHz  1.05  76%  40%  32%   0%   3%   0% 37.0°C 29.4°C   5.19V  0/6
09:54:21:  960MHz  1.20  73%  31%  36%   2%   3%   0% 37.1°C 29.2°C   5.26V  0/6
09:54:22:  960MHz  1.20  35%  28%   3%   2%   1%   0% 36.3°C 28.7°C   5.23V  0/6
09:54:23:  960MHz  1.20  24%  16%   0%   2%   5%   0% 35.6°C 28.3°C   5.25V  0/6
09:54:25:  960MHz  1.20  15%   9%   0%   1%   4%   0% 35.5°C 28.5°C   5.22V  0/6
Please note that you're now running with 4.14.14 (as expected) while you were on 4.13 before which is a bit weird given that you installed all updates.
On your screenshot the kernel panic happens with a 4.13 kernel while now after you applied all updates you're on 4.14. So my assumption is that something went wrong before (you said 'I performed apt update && apt upgrade -y and reboot the system' -- but then you should've also been running with 4.14)
@tkaiser, thank you for clarification.
It is because I provided screen captures for different attempts.
I tried to use older version of armbian, but every time I got the same version.
Now I've plugged 3A power supply and upgrade OS to the 4.14.18 version of kernel.
Take a look at mon logs: http://ix.io/13Ih.
I've posted photo for it in my first comment on this issue.
Let me duplicate it in attachment to this comment:
Spoiler
And there are no other lines, just kernel panic after this screen.
Thanks, Roman.
Please see how to increase boot verbosity: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-toogle-verbose-boot
Do you have a serial console? That would be really helpful since it allows to record the boot process with increased boot verbosity.
Then if the issue only occurs after you executed nand-sata-install can you take the SD card, access the rootfs and pastebin /var/log/armhwinfo.log and /var/log/nand-sata-install.log?
Hello @tkaiser, thank you for provided tips.
I'm still collecting this data, which you have requested and I will add it later.
Also it looks like I managed to find out one of the reason of the issue: It is new version of Silicon Power SSD drive (SP60).
The same issue I've got if try to use Banana Pi M1 with that SSDs, so issue appears not only with M1 + and also with usual M1(I have several such SSDs, so it is not a problem of a particular one).
If I transfer system to the old version of SSD, everything works.
Thanks, Roman.
I see the following lines in the kern.log:
Mar 29 18:01:22 localhost kernel: [  152.729764] EXT4-fs (sda1): Unrecognized mount option "compress-force=zlib" or missing value
Mar 29 18:01:22 localhost kernel: [  152.810043] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Looks like it tried to use 'compress-force=zlib' for EXT4 fs, is it ok?
This is harmless. But I found a serious issue in nand-sata-install.log:
Checking again for open files:
apt.syste 1377       root   11w   REG  179,1        0 35214 /var/lib/apt/daily_lock
unattende 1411       root    4uW  REG  179,1        0 35242 /var/lib/dpkg/lock
http      2483       _apt    4u   REG  179,1  4370166 37513 /var/cache/apt/archives/partial/g++-6_6.3.0-18+deb9u1_armhf.deb
That means unattended-upgrades was running while the installation has been cloned with rsync which will result in a corrupted installation for sure. This is something that needs a fix in nand-sata-install anyway. Cloning a running system is always a problem but with a running install orgy in the background it must fail.
I've tried it again with disabled unattended-update and got the same results.
Spoiler
Fri Mar 30 14:24:34 UTC 2018: Start nand-sata-install.
Old UUID:  UUID=62fc7248-9a57-4024-90d9-b4767bd2c697
SD UUID:   UUID=62fc7248-9a57-4024-90d9-b4767bd2c697
SATA UUID: UUID=efedf86c-3710-4406-86e1-5c48a9e12aef
eMMC UUID:
Boot: $1
Root: $2 /dev/sda1 ext4
Usage: 1123
Dest: 53155
/etc/fstab:
UUID=62fc7248-9a57-4024-90d9-b4767bd2c697 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
/var/swap none swap sw 0 0
/etc/mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/sda1 /mnt/nand-sata-install.iK7mhx/rootfs ext4 rw,relatime,data=ordered 0 0
Files currently open for writing:
dhclient   726       root    4w   REG  179,1     1026  37490 /var/lib/dhcp/dhclient.eth0.leases
Trying to stop running services to minimize open files:
Stopping cron.service
Copying 37336 files to /dev/sda1. Finishing transfer to USB/SATA, boot from SD/eMMC
Fri Mar 30 14:33:07 UTC 2018: Finished
So it is definitely not related to the updates.
Only one thing which make it works well is to change SSD drive, so my suggestion is only one: some errors appears because of unsupported SSD drive.
But hot to solve it?
