First of all, I'm a complete novice to Armbian so my apologies if any of the following isn't up to the standard of this board. I've just installed Armbian 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.18-sunxi on a Banana Pi. The same computer was previously running a domain controller under Bananian just fine.
Installing Samba on Armbian works fine:
r
oot@Linux08:~# apt-get install samba attr
Installing the packets to operate Samab as a DC also works fine:
root@Linux08:~# apt-get install winbind libpam-winbind libnss-winbind libpam-krb5 krb5-config krb5-user
However, attempting to provision a new Active Dirctory domain does not complete successfully.
root@Linux08:/usr/lib/arm-linux-gnueabihf# samba-tool domain provision --use-rfc2307 --interactive
Realm [ABCD.EFGH]:
 Domain [ABCD]:
 Server Role (dc, member, standalone) [dc]:
 DNS backend (SAMBA_INTERNAL, BIND9_FLATFILE, BIND9_DLZ, NONE) [SAMBA_INTERNAL]:
 DNS forwarder IP address (write 'none' to disable forwarding) [8.8.8.8]:
Administrator password:
Retype password:
Looking up IPv4 addresses
Looking up IPv6 addresses
No IPv6 address will be assigned
ldb: unable to stat module /usr/lib/arm-linux-gnueabihf/samba/ldb : No such file or directory
Setting up secrets.ldb
WARNING: Module [samba_secrets] not found - do you need to set LDB_MODULES_PATH?
Unable to load modules for /var/lib/samba/private/secrets.ldb: (null)
ERROR(ldb): uncaught exception - None
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/__init__.py", line 176, in _run
    return self.run(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/domain.py", line 462, in run
    nosync=ldap_backend_nosync, ldap_dryrun_mode=ldap_dryrun_mode)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 2124, in provision
    backend_credentials=provision_backend.credentials, lp=lp)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 957, in setup_secretsdb
    secrets_ldb = Ldb(path, session_info=session_info, lp=lp)
  File "/usr/lib/python2.7/dist-packages/samba/__init__.py", line 115, in __init__
    self.connect(url, flags, options)
Can anyone provide any help?
Thank you!
It's actually installed, unfortunately:
root@Linux08:~# apt-get install samba-dsdb-modules
Reading package lists... Done
Building dependency tree
samba-dsdb-modules is already the newest version (2:4.5.12+dfsg-2+deb9u2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
