Hello.
I'm using CubieTruck, Armbian 5.00 (Armbian_5.00_Cubietruck_Debian_jessie_3.4.110.zip).
I installed and setup mpd, using spdif port and Tos-Link cable.
Everything went well except the volume. The volume is too low to listen to the music.
I can hear that, if I turn up the external amp's volume, but even I do that to the maxium, it still is very quiet.
What can I do?
Please give me clue.
Thanks in advance~!
I tried with the Wheezy Version(Armbian_5.00_Cubietruck_Debian_wheezy_3.4.110.zip), and there was no volume issue.
I hope you find out what causes this in Jessie.
I upgraded from Wheezy to Jessie by editing the source.list file. (# sed -i 's/wheezy/jessie/g' /etc/apt/sources.list)
The upgrade was successful, and the system works fine.
Mpd volume is also quite good. (Not quiet.)
I did not modify anything but /etc/mpd.conf.
There must be miss settings on Jessie, regarding Cubietruck's spdif output.
