DuDu371 Posted April 12, 2018 Posted April 12, 2018 Hello, i'm succesfull using an armbian image from a long time. Now i compile a new image with the dev kernel (linux-sunxi right?). The problem is that, if i boot the new image the system hangs here: Spoiler U-Boot SPL 2017.11-armbian (Apr 12 2018 - 15:09:59) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):c9f55c0 NOTICE: BL3-1: Built : 15:09:28, Apr 12 2018 NOTICE: DT: sun50i-a64-pine64-plus INFO: Configuring AXP PMIC NOTICE: PMIC: fixing DRAM voltage from 1.24V to 1.36V INFO: PMIC: DRAM voltage: 1.36V INFO: PMIC: setup successful NOTICE: SCPI: dummy stub handler, implementation level: 000000 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 U-Boot 2017.11-armbian (Apr 12 2018 - 15:09:59 +0200) Allwinner Technology CPU: Allwinner A64 (SUN50I) Model: Pine64+ DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface7 eth0: ethernet@01c30000 starting USB... USB0: PA: set_value: error: gpio PA0 not reserved USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 198 ms (14.6 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 104 bytes read in 167 ms (0 Bytes/s) 29928 bytes read in 308 ms (94.7 KiB/s) 3795 bytes read in 315 ms (11.7 KiB/s) Applying kernel provided DT fixup script (sun50i-a64-fixup.scr) ## Executing script at 44000000 4029361 bytes read in 486 ms (7.9 MiB/s) 12681224 bytes read in 903 ms (13.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4029297 Bytes = 3.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49c28000, end 49fffb71 ... OK reserving fdt memory region: addr=4fa00000 size=6d000 Loading Device Tree to 0000000049bb8000, end 0000000049c27fff ... OK Starting kernel ... Loading, please wait... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.25.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 37486/68688 files, 217002/274432 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Debian GNU/Linux 8 (jessie)! Expecting device dev-ttyS0.device... [ OK ] Reached target Remote File Systems (Pre). [ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point. [ OK ] Reached target Encrypted Volumes. [ OK ] Reached target Paths. [ OK ] Reached target Swap. [ OK ] Created slice Root Slice. [ OK ] Listening on Delayed Shutdown Socket. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Created slice User and Session Slice. [ OK ] Listening on udev Control Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Journal Socket. [ OK ] Created slice System Slice. Starting Increase datagram queue length... Starting Nameserver information manager... Starting Restore / save the current clock... Starting udev Coldplug all Devices... Starting Create list of required static device nodes...rrent kernel... Mounting Debug File System... Mounting POSIX Message Queue File System... Mounting Huge Pages File System... [ OK ] Created slice system-serial\x2dgetty.slice. Starting Load Kernel Modules... [ OK ] Reached target Slices. [ OK ] Started Increase datagram queue length. [ OK ] Started Create list of required static device nodes ...current kernel. [ OK ] Started udev Coldplug all Devices. [ OK ] Started Nameserver information manager. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Debug File System. [ OK ] Started Load Kernel Modules. [ OK ] Started Restore / save the current clock. Mounting FUSE Control File System... Starting Apply Kernel Variables... Mounting Configuration File System... Starting Create Static Device Nodes in /dev... [ OK ] Listening on Syslog Socket. [ OK ] Mounted Configuration File System. [ OK ] Mounted FUSE Control File System. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Started udev Kernel Device Manager. Starting Copy rules generated while the root was ro... Starting LSB: Tune IDE hard disks... Starting LSB: Set preliminary keymap... [ OK ] Started Copy rules generated while the root was ro. [ OK ] Started LSB: Tune IDE hard disks. [ OK ] Found device /dev/ttyS0. What can i do? I want the dev kernel to have temperature and cpufreq.
