Hi. I problem with the board banana pi r1, I've installed a couple of system on it, but I can't get the ip address from the router, I have a banana pi m1 and with the same image it works, but when I remove the sd memory and install it on banana pi r1 and it doesn't work. The bpi-r1 is broken the ethernet port or something like that? When the bpi-r1 starts running turn on the green light in the ethernet port, that doesn't happen with the bpi-m1 model.
any idea, I've installed with the debian installer, but is the same problem, the ethernet doesn't work when I am configuring the net
