kristofejro Posted April 25, 2018 Posted April 25, 2018 Hi guys, I have just installed Armbian on my nanopi neo2 which works in 1-bay NAS Kit v1.2 for NanoPi NEO&NEO2 (http://www.friendlyarm.com/index.php?route=product/product&product_id=192) I have installed Armbian from image (https://dl.armbian.com/nanopineo2/Debian_stretch_next.7z). The only thing that works on it is OMV which was installed via armbian-config My system is: root@openmediavault:/# uname -a Linux openmediavault 4.14.18-sunxi64 #26 SMP Fri Feb 9 17:14:48 CET 2018 aarch64 GNU/Linux root@openmediavault:/# root@openmediavault:/# lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 9.4 (stretch) Release: 9.4 Codename: stretch root@openmediavault:/# Everything seems to be fine except watchdog module. root@openmediavault:~# systemctl status wd_keepalive.service ● wd_keepalive.service - watchdog keepalive daemon Loaded: loaded (/lib/systemd/system/wd_keepalive.service; static; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2018-04-25 17:27:41 CEST; 1min 22s ago Process: 1579 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, sta Apr 25 17:27:41 openmediavault systemd[1]: Starting watchdog keepalive daemon... Apr 25 17:27:41 openmediavault sh[1579]: modprobe: FATAL: Module softdog not found in directory /lib/modules/4.14.18-sunxi64 Apr 25 17:27:41 openmediavault systemd[1]: wd_keepalive.service: Control process exited, code=exited status=1 Apr 25 17:27:41 openmediavault systemd[1]: Failed to start watchdog keepalive daemon. Apr 25 17:27:41 openmediavault systemd[1]: wd_keepalive.service: Unit entered failed state. Apr 25 17:27:41 openmediavault systemd[1]: wd_keepalive.service: Failed with result 'exit-code'. root@openmediavault:~# root@openmediavault:~# root@openmediavault:~# systemctl status watchdog.service ● watchdog.service - watchdog daemon Loaded: loaded (/lib/systemd/system/watchdog.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2018-04-25 17:27:41 CEST; 1min 50s ago Process: 1574 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, sta Apr 25 17:27:41 openmediavault systemd[1]: Starting watchdog daemon... Apr 25 17:27:41 openmediavault sh[1574]: modprobe: FATAL: Module softdog not found in directory /lib/modules/4.14.18-sunxi64 Apr 25 17:27:41 openmediavault systemd[1]: watchdog.service: Control process exited, code=exited status=1 Apr 25 17:27:41 openmediavault systemd[1]: Failed to start watchdog daemon. Apr 25 17:27:41 openmediavault systemd[1]: watchdog.service: Unit entered failed state. Apr 25 17:27:41 openmediavault systemd[1]: watchdog.service: Triggering OnFailure= dependencies. Apr 25 17:27:41 openmediavault systemd[1]: watchdog.service: Failed with result 'exit-code'. Maybe someone of you has idea how to fix it or even workaround it?
