Andrés Rengifo Posted February 18, 2016 Posted February 18, 2016 Here my changes over the script.fex file to achieve compatibility with the 15.6FHD LCD display [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 1 screen0_output_mode = 4 screen1_output_type = 0 screen1_output_mode = 4 fb0_width = 1920 fb0_height = 1080 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 1 fb1_width = 1024 fb1_height = 600 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 0 lcd0_backlight = 0 lcd1_backlight = 197 lcd0_bright = 50 lcd0_contrast = 50 lcd0_saturation = 57 lcd0_hue = 50 lcd1_bright = 239 lcd1_contrast = 50 lcd1_saturation = 57 lcd1_hue = 50 [lcd0_para] lcd_used = 1 lcd_x = 1920 lcd_y = 1080 lcd_dclk_freq = 152 lcd_pwm_not_used = 0 lcd_pwm_ch = 0 lcd_pwm_freq = 1000 lcd_pwm_pol = 1 lcd_max_bright = 240 lcd_min_bright = 64 lcd_if = 3 lcd_hbp = 100 lcd_ht = 2226 lcd_vbp = 23 lcd_vt = 2284 lcd_vspw = 0 lcd_hspw = 0 lcd_hv_if = 0 lcd_hv_smode = 0 lcd_hv_s888_if = 0 lcd_hv_syuv_if = 0 lcd_lvds_ch = 1 lcd_lvds_mode = 0 lcd_lvds_bitwidth = 1 lcd_lvds_io_cross = 0 lcd_cpu_if = 0 lcd_frm = 1 lcd_io_cfg0 = 268435456 lcd_gamma_correction_en = 0 lcd_gamma_tbl_0 = 0x0 lcd_gamma_tbl_1 = 0x10101 lcd_gamma_tbl_255 = 0xffffff lcd_power_used = 1 lcd_power = port:PH08<1><0><default><1> lcd_pwm_used = 1 lcd_pwm = port:PB02<2><0><default><default> lcdd0 = port:PD00<3><0><default><default> lcdd1 = port:PD01<3><0><default><default> lcdd2 = port:PD02<3><0><default><default> lcdd3 = port:PD03<3><0><default><default> lcdd4 = port:PD04<3><0><default><default> lcdd5 = port:PD05<3><0><default><default> lcdd6 = port:PD06<3><0><default><default> lcdd7 = port:PD07<3><0><default><default> lcdd8 = port:PD08<3><0><default><default> lcdd9 = port:PD09<3><0><default><default> lcdd10 = port:PD10<3><0><default><default> lcdd11 = port:PD11<3><0><default><default> lcdd12 = port:PD12<3><0><default><default> lcdd13 = port:PD13<3><0><default><default> lcdd14 = port:PD14<3><0><default><default> lcdd15 = port:PD15<3><0><default><default> lcdd16 = port:PD16<3><0><default><default> lcdd17 = port:PD17<3><0><default><default> lcdd18 = port:PD18<3><0><default><default> lcdd19 = port:PD19<3><0><default><default> lcdd20 = port:PD20<3><0><default><default> lcdd21 = port:PD21<3><0><default><default>
sensometafisico Posted July 26, 2016 Posted July 26, 2016 Hi, I'm trying to do something similar with the OLIMEX 10.4" 1024x600 LCD. Any suggestions?Thanks
Andrés Rengifo Posted November 17, 2016 Author Posted November 17, 2016 Hi, I'm trying to do something similar with the OLIMEX 10.4" 1024x600 LCD. Any suggestions? Thanks Try to change this values to your desired LCD screen size [disp_init] fb0_width = 1920 fb0_height = 1080 [lcd0_para] lcd_x = 1920 lcd_y = 1080 Finally, check the LCD pin-map and change the ports according to this parameters: lcddX
