PinG Posted May 5, 2018 Posted May 5, 2018 Hello! I'm using a SinA33 board. In its MMC from the factory is installed Android. I compiled ARMbian for it. ARMbian is loaded from SD. I installed ARMbian in MMC (nand-sata-install) But when I boot from MMC - an error ... Reveal hidden contents HELLO! BOOT0 is starting! boot0 version : 3.1.0 reg_addr 0x01f00100 =0x00000000 reg_addr 0x01f00104 =0x00000000 reg_addr 0x01f00108 =0x00000000 reg_addr 0x01f0010c =0x00000000 reg_addr 0x01f00110 =0x00000000 reg_addr 0x01f00114 =0x00000000 DRAM DRIVE INFO: V1.4 DRAM CLK =552 MHZ DRAM simple test OK. dram size =1024 card boot number = 2 card no is 2 sdcard 2 line count 0 [mmc]: mmc driver ver 2014-06-05 14:18 [mmc]: ***Try SD card 2*** [mmc]: mmc 2 cmd 8 timeout, err 0x00000100 [mmc]: mmc 2 cmd 8 err 0x00000100 [mmc]: mmc 2 send if cond failed [mmc]: mmc 2 cmd 55 timeout, err 0x00000100 [mmc]: mmc 2 cmd 55 err 0x00000100 [mmc]: mmc 2 send app cmd failed [mmc]: ***Try MMC card 2*** [mmc]: MMC ver 5.0 [mmc]: SD/MMC Card: 4bit, capacity: 3728MB [mmc]: vendor: Man 0x00150100 Snr 0x0260d9e2 [mmc]: product: 4FPD3 [mmc]: revision: 5.2 [mmc]: ***SD/MMC 2 init OK!!!*** sdcard 2 init ok ERROR! NOT find the head of uboot. Ready to disable icache. Jump to Fel. P.S. I'm sorry for my English ( P.P.S I wanted to try changing /boot/script.bin, but it's missing... Where can I find it?
PinG Posted May 6, 2018 Author Posted May 6, 2018 Success! Reveal hidden contents # echo 0 > /sys/block/mmcblk1boot0/force_ro # dd if=/usr/lib/linux-u-boot-next-sin-a33_5.41_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1boot0 bs=1024 seek=8 # echo 1 > /sys/block/mmcblk1boot0/force_ro But where I can find /boot/script.bin? 1
