Things downloaded last week,
When switching to alternative kernel is executed in Armbian Config, the screen set to 1280 x 1024 has been changed to 1280 x 720 and it was not able to be rewritten, so do not run the Switch to Alternative kernel and keep the 1280 x 1024 screen It is GQRX-SDR, since error-6 (even if blacklist maintenance is done) comes out,
As a workaround, I ran Switch to the alternative kernel and avoided error-6.
(I give up on screen 1280 x 720)
But today, when downloading and installing the same software, the screen shows 1280 x 1024
It was able to be maintained.
Sorry to make software, it is truly a hard work.
But the object of today (2018/05/06), even if you run Switch to Alternative Kernel,
In GQRX-SDR, error-6 appears,
(Obviously blacklist.conf has been maintained)
From today, sdr-Radio can no longer be used.
It seems that it depends on the part of it, the kernel's performance, so please correct it.
