Hi @all,
I currently try to build a door-opener with a NanoPi Neo and a MFRC522 Rfid-Module.
Unfortunately I don't get the SPI working.
I loaded the newest Armbian-Debian from the Website:
uname -r = 4.14.18-sunxi
and downloaded the SPI-library for NanoPi:
https://github.com/wertyzp/WiringNP
By using
armbian-config
I activated "pwm", "sei-add-cs1", "spi-jedec-nor" and "spi-spidev".
The problem:
If I try to activate SPI with
gpio load spi
I get the following error-message:
modprobe: FATAL: Module spi-sun7i not found in directory /lib/modules/4.14.18-sunxi
gpio: Unable to load spi-sun7i
So it seems that wiringNp doesn't use "spi-dev" but "spi-sun7i" and I tried to install it from source from:
https://github.com/OLIMEX/OLINUXINO/blob/master/SOFTWARE/A20/A20-build-3.4.90/spi-sun7i.c
Unfortunately I can't find out how to write the Makefile so that I can compile the .ko-file and install the driver.
Can you help me writing the Makefile or have another idea how I could solve the problem?
Thanks in advance and greetings,
Latze
Edited by latze
On 5/7/2018 at 2:07 AM, latze said:
Hi @all,
By using
armbian-config
The problem:
gpio load spi
Latze
Pay attention to the theme I created, I got it and there I brought libraries that used.
https://forum.armbian.com/topic/7635-rfid-mfrc522-on-nanopi-neo/
