jock Posted May 26, 2018 Posted May 26, 2018 Is it possible to patch the device tree someway to enable HDMI output and having the console on the framebuffer for debugging in current non-development armbian version? Thanks 1
TonyMac32 Posted May 26, 2018 Posted May 26, 2018 Have not tried it so far, I guess it depends on whether a dw-hdmi driver is in there or not.
jock Posted May 27, 2018 Author Posted May 27, 2018 Mmmh, as far as I can see, the driver happens to be in mainline u-boot, the configuration allows to select HDMI driver and there are lot of references. Also there is a driver which reacts to the device tree compatible="rockchip,rk3288-dw-hdmi" string, but still I get "No signal" from my monitor. It looks like that everything is in place but there is just a missing switch that turns on HDMI :/
TonyMac32 Posted May 27, 2018 Posted May 27, 2018 You have to declare the console going to the HDMI in the config
jock Posted May 27, 2018 Author Posted May 27, 2018 This is the u-boot environment: Spoiler arch=arm baudrate=115200 board=xt-q8l-v10_rk3288 board_name=xt-q8l-v10_rk3288 boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=mmc0 mmc1 usb0 pxe dhcp bootcmd=run distro_bootcmd bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; ; bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_mmc1=setenv devnum 1; run mmc_boot bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi bootcmd_usb0=setenv devnum 0; run usb_boot bootdelay=0 cpu=armv7 distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ fdt_addr_r=0x01f00000 fdt_high=0x0fffffff fdtcontroladdr=7cf669a8 initrd_high=0x0fffffff kernel_addr_r=0x02000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi partitions=uuid_disk=${uuid_gpt_disk};name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};name=reserved1,size=64K,uuid=${uuid_gpt_reserved1};name=reserved2,size=4M,uuid=${uuid_gpt_reserved2};name=loader2,size=4MB,uuid=${uuid_gpt_l; preboot=usb start pxefile_addr_r=0x00100000 ramdisk_addr_r=0x04000000 reset_reason=POR scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_foe scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} e scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x00000000 soc=rockchip stderr=serial,vidconsole stdin=serial,usbkbd stdout=serial,vidconsole usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi vendor=rockchip Environment size: 4252/8188 bytes I see stdout and stderr pointing to vidconsole, I guess it means it is enabled in u-boot config, isn't it? Also coninfo command tells this when an HDMI display is connected to the device Spoiler => coninfo List of available devices: serial@ff690000 00000007 IO serial 00000003 IO stdin nulldev 00000003 IO vidconsole 00000002 .O stdout stderr And if I disconnect the monitor, the vidconsole entry disappears. So it makes me guess that u-boot sees the display, but does not activate it for some reason.
jock Posted June 24, 2018 Author Posted June 24, 2018 A nice recent finding: in u-boot console using the i2c command is useful to report the EDID of the connected monitor. Setting the i2c bus to 5 and reading from address 50 reports the proper EDID of my monitor: => i2c dev 5 Setting bus to 5 => i2c edid 50 EDID version: 1.3 Product ID code: 562d Manufacturer: IVM Serial number: 000001ae Manufactured in week: 6 year: 2016 Video input definition: digital signal, voltage level 0 Monitor is non-RGB Maximum visible display size: 51 cm x 29 cm Power management features: active off, no suspend, no standby Estabilished timings: 720x400 70 Hz (VGA 640x400, IBM) 640x480 60 Hz (VGA) 640x480 67 Hz (Mac II, Apple) 640x480 75 Hz (VESA) 800x600 56 Hz (VESA) 800x600 60 Hz (VESA) 800x600 75 Hz (VESA) 1024x768 60 Hz (VESA) 1024x768 70 Hz (VESA) 1024x768 75 Hz (VESA) 1280x1024 75 (VESA) Standard timings: 1920x1080 60 Hz 1280x1024 60 Hz 1440x900 60 Hz 1680x1050 60 Hz 1280x960 60 Hz 1152x864 75 Hz 1440x900 75 Hz 1920x1080 60 Hz (detailed) Monitor range limits, horizontal sync: 30-83 kHz, vertical refresh: 55-76 Hz, max pixel clock: 170 MHz Monitor serial number: 11298JG20043 Monitor name: PL2390 But the monitor is just in suspend mode, not displaying anything. It is turned on later when the kernel probes for mali gpu. This should prove that the HDMI interface is *really* working, but there are some "minor" bits to turn on the display
