I've been trying to activate the framebuffer on a Armbian Debian-server image.  The framebuffer doesn't exist on a server image but I need to be able to install it.
So I thought, what about DirectFB.  I've been searching the web for instructions on installing DirectFB.  I need to install it and not have to burn a new image (I'm not capable).
I just noticed that if I go to /boot/debian i find all the libdirectfb files.
Can somebody show me (step by step) how I could install DirectFB or directly activate the framebuffer using these files?  What files (including directories) to install, scripts to modify, etc.
Any help would be appreciated.
DirectFB is a abstraction level over initiated framebuffer.
Does "sudo ls /dev/fb*" show anything?
How does your display connected?
@YaR
Sorry, I was out of town this morning.
The response to "sudo ls /dev/fb*" is
         ls: cannot access '/dev/fb*': No such file or directory
If I log in as root or myself I get the same response.
I can connect through SSH or directly through the keyboard to look for the framebuffer.  I get the same response.
The display is attached through HDMI.  The system correctly knows if the HDMI is connected or disconnected.
Just no sign of the framebuffer.
This is a server version as I don't need a GUI.
Any suggestions?
