Docker won't start on orangepizero 4.14.14-sunxi #1 SMP Thu Jan 25 12:20:57 CET 2018 armv7l GNU/Linux
I'm very happy to have my OrangePi Zero working (at last!) with Armbian. :D
It looks like docker installed properly on the latest Armbian Stretch mainline kernel 4.14.y, but for some reason, it won't start.
Here are the logs I have:
systemctl enable docker
Synchronizing state of docker.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable docker
root@orangepizero:~# systemctl start docker
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
root@orangepizero:~# systemctl status docker.service
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2018-06-03 12:43:49 UTC; 8s ago
     Docs: https://docs.docker.com
  Process: 20147 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILURE)
 Main PID: 20147 (code=exited, status=1/FAILURE)
      CPU: 990ms
Jun 03 12:43:48 orangepizero systemd[1]: docker.service: Unit entered failed state.
Jun 03 12:43:48 orangepizero systemd[1]: docker.service: Failed with result 'exit-code'.
Jun 03 12:43:49 orangepizero systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Jun 03 12:43:49 orangepizero systemd[1]: Stopped Docker Application Container Engine.
Jun 03 12:43:49 orangepizero systemd[1]: docker.service: Start request repeated too quickly.
Jun 03 12:43:49 orangepizero systemd[1]: Failed to start Docker Application Container Engine.
Jun 03 12:43:49 orangepizero systemd[1]: docker.service: Unit entered failed state.
Jun 03 12:43:49 orangepizero systemd[1]: docker.service: Failed with result 'exit-code'.
root@orangepizero:~# uname -a
Linux orangepizero 4.14.14-sunxi #1 SMP Thu Jan 25 12:20:57 CET 2018 armv7l GNU/Linux
Is there anything I can do to get it working?
Here are the diagnosis: diagnosis.
Thanks.
Edited by gounthar
Added diagnosis
After several reboots, docker seem to work now (without any further modifications).
Go figure...
 docker images
REPOSITORY          TAG                 IMAGE ID            CREATED              SIZE
<none>              <none>              b12376e7113c        About a minute ago   7.79MB
armhf/alpine        latest              15ed6d4bf10d        12 months ago        3.6MB
Edited by gounthar
Duplication of code
