Hi every devs !
(some of you know that I was on other duties those past months, mainly constructing my new house and moving in it, but I'm now back to Armbian builds those recent days after more then 6 busy months)
I've noticed yesterday that USB1-DRVVBUS/PD7 was not activated any more in my recent build, although the fix-many-orangepiwin-dts.patch should take care of that and this one is successfully applied.
After digging the issue, I've found out that the sunxi64-hdmi-thermal-dma-pmw-enable.patch is reverting many of those, probably unintentionally, and since this patch is applied after the first one, things are revert silently.
Should I simply trim the sunxi64-hdmi-thermal-dma-pmw-enable.patch the unwanted reverts ?
Edit : Igor ? It seems that those collisions have been introduced on Jan 3rd ... Were they intentionals, or was that patch generated without properly applying others ?
+diff --git a/arch/arm64/boot/dts/allwinner/sun50i-a64-orangepi-win.dts b/arch/arm64/boot/dts/allwinner/sun50i-a64-orangepi-win.dts
+index 6ecb700..376d7bf 100644
+--- a/arch/arm64/boot/dts/allwinner/sun50i-a64-orangepi-win.dts
++++ b/arch/arm64/boot/dts/allwinner/sun50i-a64-orangepi-win.dts
+@@ -51,31 +51,15 @@
+ compatible = "xunlong,orangepi-win", "allwinner,sun50i-a64";
+ aliases {
++ ethernet0 = &emac;
+ serial0 = &uart0;
++ serial1 = &uart1;
+ chosen {
+ stdout-path = "serial0:115200n8";
+- reg_vcc3v3: vcc3v3 {
+- compatible = "regulator-fixed";
+- regulator-name = "vcc3v3";
+- regulator-min-microvolt = <3300000>;
+- regulator-max-microvolt = <3300000>;
+- reg_usb1_vbus: usb1-vbus {
+- regulator-name = "usb1-vbus";
+- regulator-min-microvolt = <5000000>;
+- regulator-max-microvolt = <5000000>;
+- regulator-boot-on;
+- enable-active-high;
+- gpio = <&pio 3 7 GPIO_ACTIVE_HIGH>;
+- status = "okay";
+ wifi_pwrseq: wifi_pwrseq {
+ compatible = "mmc-pwrseq-simple";
+ reset-gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 */
+ &usbphy {
+- usb1_vbus-supply = <&reg_usb1_vbus>;
+ status = "okay";
Edit2 : I've committed the fix, hopefully it doesn't break any thing else ...
https://github.com/armbian/build/commit/c0a40f327c5024392c1d59c23611d9e6abb18c38#diff-5dbb1fe61dcfe9a242fef90ea4f6f544
