Darryl Posted June 25, 2018 Posted June 25, 2018 I'm running the latest lime1 armbian (linux 4.14) and am having great difficulty controlling the mic levels. amixer yields: Simple mixer control 'Left Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Power Amplifier',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 63 Mono: 48 [76%] [-15.00dB] Simple mixer control 'Power Amplifier DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Power Amplifier Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Power Amplifier Mute',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Right DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] which does not include any control for the mic. Using alsamixer a mix control is presented in the capture view, but it appears to be a duplicate of the speaker volume adjusting that instead. Playback and record both work, I am just unable to control the recording volume in anyway. Has anybody else had this issue and been able to get the mic volume working on this platform? I'd really appreciate knowing how you resolved it.
theosoft Posted September 11, 2018 Posted September 11, 2018 Hello, I do have the same efect. No MIC / Linein devices in alsamixer or elsewhere uname -a Linux bananapi 4.14.18-sunxi #24 SMP Fri Feb 9 16:24:32 CET 2018 armv7l GNU/Linux arecord -L null Discard all samples (playback) or generate zero samples (capture) default:CARD=sun4icodec sun4i-codec, Default Audio Device sysdefault:CARD=sun4icodec sun4i-codec, Default Audio Device dmix:CARD=sun4icodec,DEV=0 sun4i-codec, Direct sample mixing device dsnoop:CARD=sun4icodec,DEV=0 sun4i-codec, Direct sample snooping device hw:CARD=sun4icodec,DEV=0 sun4i-codec, Direct hardware device without any conversions plughw:CARD=sun4icodec,DEV=0 sun4i-codec, Hardware device with all software conversions I enabled analog-codec with armbian-config. Entry "overlays=analog-codec" in /etc/armbianEnv.txt present U-Boot says, the overlay is loaded. Reboot sequence lsmod Module Size Used by sun4i_gpadc_iio 16384 0 evdev 20480 1 sun4i_codec 32768 3 snd_soc_core 118784 1 sun4i_codec snd_pcm_dmaengine 16384 1 snd_soc_core sun4i_ts 16384 0 snd_pcm 65536 4 snd_pcm_dmaengine,snd_soc_core ir_lirc_codec 16384 0 lirc_dev 16384 1 ir_lirc_codec snd_timer 24576 1 snd_pcm sun4i_gpadc 16384 0 snd 45056 5 snd_timer,snd_soc_core,snd_pcm nvmem_sunxi_sid 16384 0 soundcore 16384 1 snd sunxi_cir 16384 0 sun4i_ss 24576 0 uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq bonding 94208 0 brcmfmac 159744 0 brcmutil 16384 1 brcmfmac cfg80211 376832 1 brcmfmac rfkill 20480 2 cfg80211 ip_tables 20480 0 x_tables 20480 1 ip_tables uas 20480 0 realtek 16384 1 CON1 LINEIN is connected with a audio source. But arecord failes. For me there seems something is missing in devicetree definitions? regards
OpenglMan Posted January 2, 2019 Posted January 2, 2019 I have the same problem. Besides i have a LIME1 and Cubieboard2, and i have the same problem in both boards. Armbian mainline Kernel It seems an important fail. A solution can be to use Pulse. With Pulse installed, you can see Master and Capture controls if you type 'amixer' I also think there is probably an error with the devicetree definition. If not, maybe there is a problem in the driver sun4i_codec In 3.4 kernel, i can see: Simple mixer control 'Master',0 Capabilities: pvolume pvolume-joined penum Playback channels: Mono Limits: Playback 0 - 63 Mono: Playback 63 [100%] Simple mixer control 'Master Capture Mute',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'LineL',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'LineR',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'Linein Pre-AMP',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 4 [57%] Simple mixer control 'Mic Input Mux',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 15 Mono: 0 [0%] Simple mixer control 'Mic Power',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [off] Simple mixer control 'Mic1 Boost',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mic1 gain',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 3 Mono: 0 [0%] Simple mixer control 'Mic2 Boost',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [off] Simple mixer control 'Mic2 gain',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 4 [57%] Simple mixer control 'MicL',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 3 Mono: 1 [33%] Simple mixer control 'MicR',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 3 Mono: 3 [100%] Simple mixer control 'Playback',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [off] Simple mixer control 'Capture',0 Capabilities: cvolume cvolume-joined penum Capture channels: Mono Limits: Capture 0 - 7 Mono: Capture 6 [86%] Simple mixer control 'ADC Input Mux',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 2 [29%] Simple mixer control 'Fm output',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 3 [43%] Simple mixer control 'FmL',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'FmR',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'LINEIN APM',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] Simple mixer control 'Ldac Left Mixer',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'Ldac Right Mixer',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left Capture Mute',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [off] Simple mixer control 'MIC output volume',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 3 [43%] Simple mixer control 'Rdac Right Mixer',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Capture Mute',0 Capabilities: pswitch pswitch-joined penum Playback channels: Mono Mono: Playback [off] In mainline kernel I can see: Simple mixer control 'Left Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Power Amplifier',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 63 Mono: 45 [71%] [-18.00dB] Simple mixer control 'Power Amplifier DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Power Amplifier Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Power Amplifier Mute',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Mixer Left DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Right DAC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Maybe the following link is related to this error: http://lists.infradead.org/pipermail/linux-arm-kernel/2015-December/392419.html
