orel Posted April 3, 2020 Share Posted April 3, 2020 Hello, I try to re-install my olimex lime 1, but I'm unable to boot from the current buster image. For now, here's what I do to flash the sd card: % wget -c "https://dl.armbian.com/lime/Buster_current" % mv Buster_current Armbian_20.02.1_Lime_buster_current_5.4.20.7z % 7z x Armbian_20.02.1_Lime_buster_current_5.4.20.7z % sudo sh -c "dd if=Armbian_20.02.1_Lime_buster_current_5.4.20.img of=/dev/sdc bs=1M" And I come up with a result like this: % sudo sfdisk -d /dev/sdc label: dos label-id: 0xd9b237ef device: /dev/sdc unit: sectors /dev/sdc1 : start= 8192, size= 2318336, type=83 Is this empty space before the first partition normal or am I missing something? Link to comment Share on other sites More sharing options...
Igor Posted April 3, 2020 Share Posted April 3, 2020 2 hours ago, orel said: here's what I do to flash the sd card: This is the proper way:https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card It is essential to read what you write when using SD cards. 2 hours ago, orel said: Is this empty space before the first partition normal or am I missing something? Yes, its normal. There is a place for boot loader. Edit: Bionic version works for me. Link to comment Share on other sites More sharing options...
orel Posted April 3, 2020 Author Share Posted April 3, 2020 Thank's for the reactivity. I use this : sudo sh -c "cat Armbian_20.02.1_Lime_buster_current_5.4.20.img | pv | dd of=/dev/sdc bs=1M" and it works better now :-) 3 hours ago, Igor said: This is the proper way:https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card It is essential to read what you write when using SD cards. at the beginning, I used "dd" without "cat" because it is indicated in the file "Armbian_20.02.1_Lime_buster_current_5.4.20.img.txt" as one of the 4 methods to prepare the SD card. Thanks again! Link to comment Share on other sites More sharing options...
