Nick Posted March 2, 2016 Posted March 2, 2016 I'm currently playing with a Banana Pi M1 + and don't seem to be able to get the GPIO to work. I *think* that I have correctly mapped the IO pins that I am using through the schematic and fex file to find the corrisponding GPIO number for debian. When playing around in /sys/class/gpio I am able to export the GPIO pin that I'm looking for and change it's properties, direction, value etc. However these changes don't seem to appear on the physical IO pins. I noticed that some of the pins that I'm using are shared by UART 2, so I have disabled that in the FEX file but still no luck. I have a feeling that this is probably going to be DTB related, however I'm a little confused by the fact that Debian allows me to export them.
zador.blood.stained Posted March 3, 2016 Posted March 3, 2016 GPIO pin numbering schemes are different in legacy kernel (and fex file) and in mainline kernel: https://linux-sunxi.org/GPIO If you are using mainline kernel, you need to map board expansion pin to SoC port bank and number using schematics (or wiki) (i.e. PH10) and use formula in wiki to calculate correct GPIO pin number for exporting.
Nick Posted March 3, 2016 Author Posted March 3, 2016 Hi Zador, Once again you come to my rescue, thank you :-) I have the GPIO working now, just trying to debug the SPI port. I have a device but no pins toggling at the moment. Just out of interest, is the FEX file used at all by mainline now, or does it just use DTB?
zador.blood.stained Posted March 3, 2016 Posted March 3, 2016 FEX file is used only by legacy kernel, mainline used DT instead (essentially for the same purpose - providing board-specific configuration).
Nick Posted March 3, 2016 Author Posted March 3, 2016 Brilliant, that's good to know, at least I can just concentrate on checking the settings in mainline without having to worry about the FEX file as well. Just out of interest, if I'm using mainline, is the FEX file used at all, for example by UBOOT or the SoC's internal bootloader? In other words, if were to delete the fex file from the SD card whilst using mainline would it still work? Getting back to the SPI... I've checked and re-checked my DTB file (including decompiling the file on the device), and SPI appears to be enable, it appears to be using the correct pins as per the schematic and spidev32766.0 appears in /dev My code (which worked with the legacy kernel) is very similar to the code found here: https://linux-sunxi.org/SPIdev there are no apparent erros when the code runs, but nothing is output on any of the physical SPI pins.
zador.blood.stained Posted March 3, 2016 Posted March 3, 2016 Just out of interest, if I'm using mainline, is the FEX file used at all, for example by UBOOT or the SoC's internal bootloader? In other words, if were to delete the fex file from the SD card whilst using mainline would it still work? FEX file isn't ised in legacy kernel too It's compiled to bin file, which is used by legacy kernel. In any case u-boot uses its own precompiled configuration and DT file, so deleting .bin and .fex file has no effect when using mainline kernel.
Nick Posted March 3, 2016 Author Posted March 3, 2016 True, I probably should have mentioned that the FEX file is compiled first for completeness :-)
Nick Posted March 3, 2016 Author Posted March 3, 2016 Looking at the signals on a scope, the CLK pin is awful. I've tried increasing the drive strength to 40mA in the DTB file to no avail. The MOSI line looks fine on the scope, but the CLK line looks more like a sinewave that a square wave. If I override the CLK pin using the /sys/class/gpio then the line goes high, so I am confident that there are no electrical shorts on the board.
Nick Posted March 3, 2016 Author Posted March 3, 2016 Here is my SPI code #include "system.h" #include "spi.h" #include "debug.h" #include <stdint.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> #include <getopt.h> #include <fcntl.h> #include <sys/ioctl.h> #include <linux/types.h> #include <linux/spi/spidev.h> static const char *device = "/dev/spidev32766.0"; static uint8_t mode; static uint8_t bits = 8; static uint32_t speed = 500000; static uint16_t delay; static unsigned char rxByte; int fd; static void pabort(const char *s) { perror(s); abort(); } void spiInit(void) { unsigned int ret; printf("SpiInit()..."); fd = open(device, O_RDWR); if (fd < 0) { printf("can't open device: %s\r\n", device); abort(); } // mode |= SPI_LOOP; //mode |= SPI_CPHA; //mode |= SPI_CPOL; //mode |= SPI_LSB_FIRST; // mode |= SPI_CS_HIGH; // mode |= SPI_3WIRE; //mode |= SPI_NO_CS; // mode |= SPI_READY; /* * spi mode */ ret = ioctl(fd, SPI_IOC_WR_MODE, &mode); if (ret == -1) pabort("can't set spi mode"); ret = ioctl(fd, SPI_IOC_RD_MODE, &mode); if (ret == -1) pabort("can't get spi mode"); /* * bits per word */ ret = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, &bits); if (ret == -1) pabort("can't set bits per word"); ret = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bits); if (ret == -1) pabort("can't get bits per word"); /* * max speed hz */ ret = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed); if (ret == -1) pabort("can't set max speed hz"); ret = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed); if (ret == -1) pabort("can't get max speed hz"); printf("Done.\r\n"); } void spiTxByte(unsigned char byte) { unsigned int ret; struct spi_ioc_transfer tr = { .tx_buf = (unsigned long)&byte, .rx_buf = (unsigned long)&rxByte, .len = 1, .delay_usecs = delay, .speed_hz = speed, .bits_per_word = bits, }; ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr); // printf("spi: by: %#x, rxB: %#x\r\n",byte, rxByte); if (ret < 1) pabort("can't send spi message"); } unsigned char spiRxByte(void) { spiTxByte(0x00); return rxByte; }
zador.blood.stained Posted March 4, 2016 Posted March 4, 2016 Looking at the signals on a scope, the CLK pin is awful. I've tried increasing the drive strength to 40mA in the DTB file to no avail. The MOSI line looks fine on the scope, but the CLK line looks more like a sinewave that a square wave. If I override the CLK pin using the /sys/class/gpio then the line goes high, so I am confident that there are no electrical shorts on the board. I just looked at SPI on cubietruck with mainline kernel. I used spidev_test.c, and for some reason it ignores max speed settings and always goes at 50MHz (probably from DT setting "spi-max-frequency = <50000000>;"). At this speed it's hard to expect square signal on CLK pin. Try lowering max speed in DT at least to 1MHz (maybe I'll try it too later when I have some spare time).
Nick Posted March 4, 2016 Author Posted March 4, 2016 Ahh that's where spi_test is, I tried looking for it but ended up at a page (I think on kernel.org) that just had a nice explanation of it instead :-( I'll try those changes, thank you. My scope is only 70MHz so I doubt it was able to do much with a 50MHz signal. The chip that I'm trying to talk to certainly wouldn't handle it! Thanks for the tip, I'll let you know how I get on :-)
zador.blood.stained Posted March 4, 2016 Posted March 4, 2016 I'll try those changes, thank you. My scope is only 70MHz so I doubt it was able to do much with a 50MHz signal. The chip that I'm trying to talk to certainly wouldn't handle it! Mine is 60MHz, but here it doen't matter, you should be able to measure frequency on SCK pin in any case.
Nick Posted March 4, 2016 Author Posted March 4, 2016 60 / 70 MHz would allow you to measure the frequency but probably wouldn't give you much of a square wave as it's too close to the frequency being measured. I wouldn't trust a 70MHz scope to display much more than a 35/40MHz signal as the Nyquist frequency is Fsample / 2. That said, I didn't think to measure / calculate the frequency at all, I just saw the awful wave. Had I thought to measure it I probably would have noticed that it was 50MHz. Just for reference, I've changed the Max frequency in the DTB file to 5MHz and everything is working brilliantly now, thank you very much.
ChrisArena52 Posted June 9, 2016 Posted June 9, 2016 On my Legacy CB1 system, I'm not seeing the gpiochip0 under /sys/class/gpio. For my case: root@cubieboard:/sys/class/gpio# uname -a Linux cubieboard 3.4.112-sun4i #1 PREEMPT Wed Jun 8 11:09:31 EDT 2016 armv7l GNU/Linux root@cubieboard:/sys/class/gpio# lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 8.5 (jessie) Release: 8.5 Codename: jessie root@cubieboard:/sys/class/gpio# ls -la total 0 drwxr-xr-x 2 root root 0 Dec 31 1969 . drwxr-xr-x 57 root root 0 Dec 31 1969 .. --w------- 1 root root 4096 Jun 9 14:17 export --w------- 1 root root 4096 Dec 31 1969 unexport root@cubieboard:/sys/class/gpio# Is there something that qualifies that? I did the operation dd if=CB1_U-Boot of=/dev/sdd bs=1k seek=8 to overwrite the built in u-boot with the one that Steve gave me (see http://forum.armbian.com/index.php/topic/1178-cubieboard-1-legacy-boot-failure/?p=10244), as the default u-boot was hanging for CB's although not other hardware. Steve's version boots up. Is there something else required to enable GPIO? Did overwriting the original u-boot disconnect something? Thanks Chris
ChrisArena52 Posted June 9, 2016 Posted June 9, 2016 Additional data point: I get this in dmesg: [ 0.133078] sunxi_gpio driver init ver 1.3 [ 0.139085] sunxi_gpio_probe can't find script.bin '[gpio_para]' 'gpio_used' [ 0.144097] gpio-sunxi: probe of gpio-sunxi failed with error -4 Can't find script.bin ? where is it looking? It's in the usual place. Chris
ChrisArena52 Posted June 9, 2016 Posted June 9, 2016 I found the problem: I have no gpio_para section in my script.bin. I modified the default script.bin turning on SPI, but I didn't check the GPIO section. Its missing in the default script.bin for some reason. Chris
