Larry Bank Posted July 15, 2018 Posted July 15, 2018 Today's project is trying to get my game emulator to run on the NanoPi NEO Core board. Lots of exposed I/O, but I'm getting random hangs and some odd behavior with the latest Armbian. In the photo is a ILI9342 (landscape version) 2.3" display and some ugly protoboards I created to allow reliable wiring + sockets for the Core board. I just updated my SPI_LCD project to include support for both the ILI9342 and the Core board's strange header: https://github.com/bitbank2/SPI_LCD I had to wire the USB-A socket to the header because the OTG port is not properly enabled (in the available Armbian build). If I spent some time messing with it, there's probably a bunch of patches to get it working, but soldering 4 wires seemed like the quicker fix for me. I'll keep you posted on my progress (if anyone is interested) 2
Larry Bank Posted July 15, 2018 Author Posted July 15, 2018 Update: Everything working now. These issues are resolved: 1) Constant hangs were due to the cheap wifi adapter. It would hang the ssh session after 5-10 minutes of use. Switched to a better one and it now works reliably 2) GPIO didn't behave the same as other systems. I had to add lseek(handle, 0, SEEK_SET) before each read from a GPIO pin. I should have done it earlier, but other machines seem to work without needing that 3) Now I need to solder a 3.5mm socket onto the analog audio out to hear the output... Here's a video of it in action: https://photos.app.goo.gl/zLZS3Pw3iABCXVkK9 2
Larry Bank Posted July 17, 2018 Author Posted July 17, 2018 I retested with NanoPi's Linux distro and it has USB OTG and analog audio working by default. 1
